Old 06-27-2011, 05:27 PM   #1
Bilcin's Avatar
LP tank stuck safety valve.
Wife just got back from Wildwood NJ. Spent 4 days there with the kids. First time we used our brand new 2011 Wildwood 26tbss. Only problem she had was that when she went to light the water heater it would not light. I told her to switch the LP tank to the other tank (in case it was empty ). She switched it and that solved the problem. Today I took both tanks to be refilled before my next trip and she said both tanks (30 lbs each) were still almost full! I told her one didnt' have any flow from it and she said let me use a valve tester. She screwed it on the tank, opened the valve slowly, nothing happened. She closed it and opened it again and this time I heard a click, she said the safety valve was stuck and it is now open and propane came out when she opened it. I was pleasently surprised that with the water heater on for 4 days and with cooking breakfast and lunch it used hardly any propane.
Bill
Bill & Cindy McKenna
Philadelphia PA
2015 Palomino Puma 32DBKS
2005 Ford Excursion 6 liter Turbo Diesel
Bilcin is offline   Reply With Quote
Old 06-29-2011, 09:28 AM   #2
Bruck's Avatar
I have a lot of trouble lighting my water heater as well. Takes a bit to get the pilot light going and then you have to be really careful turning to the on position. You just have to get the technique down I guess.
Bruck is offline   Reply With Quote
Old 07-20-2011, 08:42 PM   #3
Same here with my 2012 26tbss...
BADIE
2009 F-150 SUPERCREW 5.4
2012 WILDWOOD 26TBSS
Badie is offline   Reply With Quote
Old 07-20-2011, 09:07 PM   #4
papap's Avatar
Sometimes if the over fill the bottle you have a hard time getting them to flow.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
