03-14-2016, 04:09 PM
making room to open the tailgate
Has anyone tried to turn the electric jack so that the tailgate can be opened when the truck is connected to the trailer hitch? or if the whole unit can be unbolted and spun for better clearance?
I appreciate the feedback.
2015 FR Wildwood X-Lite 262BHXL
2007 F250 4wd CC SB 6.0 Diesel
03-14-2016, 04:10 PM
Left Coast
Been other threads and posts of folks doing it
03-14-2016, 04:31 PM
Some Brands of Elec.Jacks,the motor can be turned,some Members if they Only need "1-2"" to clear the Jack drill another 5/8" hole "Downstream" in the "Ball Mount" shaft! Some Ball Mounts come with two 5/8" holes in them! Youroo!!
03-14-2016, 04:53 PM
I will try some further searching. ty
03-14-2016, 08:22 PM
I was able to turn my UF 3500's motor 180° and now have no problem dropping the tailgate.
03-14-2016, 08:25 PM
Between this forum and some other forums, I have seen it done.
2014 Sabre 34REQS-6
03-15-2016, 08:55 AM
I read where it had been done as well. Sounds like you can unbolt the entire unit and rotate it. If the motor/electronic box itself can be turned that would be just as good in my opinion. I will have to look at what brand mine is at home. Wait for a dry day and see what i can get done.
03-15-2016, 09:02 AM
Yes, the jack does motor does not care what way it faces...
03-15-2016, 09:04 AM
Barker units allow Head rotation also! The Bolt Base pattern will NOT allow Jacks to be located in the location you desire! Youroo!!
03-15-2016, 09:44 AM
As a last resort, if the motor can't be turned, just take it to a welding shop and have the mounting plate cut off, rotated and re-welded. Shouldn't take but about 30 minutes start to finish.
03-15-2016, 11:53 AM
i wiped one out smashed the rocker switch other truck not as close as this truck
03-15-2016, 01:38 PM
The easiest solution is to get a longer shank for the hitch. All of the manufacturers make them in different lengths. Just determine how much too close you are and get an shank extended by that amount. Should cost about $100.
As has been stated, a Barker, which I have, allows you to turn the head 90 degrees. I had a Trailer Star which did not allow this. I would not attempt to drill an additional hole in your hitch draw bar. This would decrease the length inserted into your receiver resulting in more leverage exerted on it, possibly exceeding the design strength. Selling your jack, if it does not rotate, then buying one that does might be your best bet.
2015 GMC Sierra 1500
2013 Heartland North Trail 28BRS
03-15-2016, 04:02 PM
AKA: 'tiredTeacher
Good advice. Rotating the motor head is a no-go on my jack. Turning the whole thing 120° to line up the existing holes and plate puts the jack motor into the propane bottles.
Your solution is the one I came up with, also. Just ain't got rountuit.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
