Old 03-14-2016, 05:09 PM   #1
making room to open the tailgate
Has anyone tried to turn the electric jack so that the tailgate can be opened when the truck is connected to the trailer hitch? or if the whole unit can be unbolted and spun for better clearance?
I appreciate the feedback.
2015 FR Wildwood X-Lite 262BHXL
2007 F250 4wd CC SB 6.0 Diesel
5LowesOR is offline   Reply With Quote
Old 03-14-2016, 05:10 PM   #2
Left Coast
Been other threads and posts of folks doing it
Old 03-14-2016, 05:31 PM   #3
Some Brands of Elec.Jacks,the motor can be turned,some Members if they Only need "1-2"" to clear the Jack drill another 5/8" hole "Downstream" in the "Ball Mount" shaft! Some Ball Mounts come with two 5/8" holes in them! Youroo!!
Old 03-14-2016, 05:53 PM   #4
I will try some further searching. ty
Old 03-14-2016, 09:22 PM   #5
bikendan's Avatar
I was able to turn my UF 3500's motor 180į and now have no problem dropping the tailgate.
Equalizer WDH
Old 03-14-2016, 09:25 PM   #6
asquared's Avatar
Between this forum and some other forums, I have seen it done.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 03-15-2016, 09:55 AM   #7
I read where it had been done as well. Sounds like you can unbolt the entire unit and rotate it. If the motor/electronic box itself can be turned that would be just as good in my opinion. I will have to look at what brand mine is at home. Wait for a dry day and see what i can get done.
Old 03-15-2016, 10:02 AM   #8
Yes, the jack does motor does not care what way it faces...
2016 Siverback 33IK
dalford is online now   Reply With Quote
Old 03-15-2016, 10:04 AM   #9
Barker units allow Head rotation also! The Bolt Base pattern will NOT allow Jacks to be located in the location you desire! Youroo!!
Old 03-15-2016, 10:44 AM   #10
As a last resort, if the motor can't be turned, just take it to a welding shop and have the mounting plate cut off, rotated and re-welded. Shouldn't take but about 30 minutes start to finish.
roo
