Old 08-11-2015, 11:57 AM   #1
Microwave hood light bulb
where can I find one of these bulbs? I am also interested in swapping all of the interior lights for LED if possible. Anyone have links to these.
2015 Wildwood 262BHXL
2015 FR Wildwood X-Lite 262BHXL
2007 F250 4wd CC SB 6.0 Diesel
5LowesOR is offline   Reply With Quote
Old 08-11-2015, 12:13 PM   #2
Boss Ox & Drovergirl
oxcamper's Avatar
got my replacements at an rv dealer, bought several. these things seem to burn out pretty quick.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 08-11-2015, 01:39 PM   #3
Tfort's Avatar
Most of these bulbs are just automotive bulbs but if you want to go LED then you will need to go to an RV store.
Tfort is offline   Reply With Quote
Old 08-11-2015, 02:00 PM   #4
No you don't unless you don't minding spending way more on led's. Go to ebay and search the type of bulb you want. Most, if you drill deep enough, are dirt cheap. Remember, it's all made in china anyway. Some, have circuitry that, according to clams, limit EMF noise with sound systems. But, I went cheap and had no issues. Just sayin'
Old 08-12-2015, 12:27 AM   #5
Go Pack Go!!
codespy's Avatar
I have tried 15 different brands. These are the best bright warm white's that I could find to replace the 921's.
Amazon.com: GRV T10 Wedge 921 194 25-3528 SMD LED Bulb lamp Super Bright Warm White DC 12V Pack of 10: Automotive
1994 Damon Hornet 27R
2016 Wildwood 4092BFL (Still Getting Fixed by Dealer After Production)
codespy is offline   Reply With Quote
Old 08-12-2015, 11:56 AM   #6
I replaced all my bulbs with these from amazon a ten pack is about $20 they work great and are bright.
GRV T10 921 194 24-3528 SMD LED Bulb lamp Super Bright Warm White DC 12V Pack of 10
edcronin01 is offline   Reply With Quote
Old 08-12-2015, 01:01 PM   #7
LED Bulbs
I agree 100%. I wasn't sure of exact specs so I experimented three times to the tune of a total of @ $65. Ended up with just what I wanted for 21 lights. That's $3/ light even considering the ones I didn't use. Beats the hell out of CW at @ $10-12/ bulb. Here is what I ended up using. 10 Pcs T10 68 SMD W5W 168 194 LED Warm White Interior Dome Map Door Light Lamps | eBay
VMI'62
Edmund is offline   Reply With Quote
Old 08-12-2015, 09:58 PM   #8
NAPA had them for us, we were camping in another state and there wasn't an RV dealer near us. I removed the bulb and walked right in they took and matched it up of course I got a whole bunch more as they were very reasonable.
When we got back it plugged right in and was the same color and brightness.
Good luck going LED
Oldairmech is offline   Reply With Quote
Old 08-12-2015, 10:06 PM   #9
Boat, RV and Other LED Bulbs - Super Bright LEDs
I got warm white for the ceiling lights couple years ago.
Dobe Fanatic - Largo, Florida
2012 Flagstaff T12RB A-Frame
DobeFanatic is offline   Reply With Quote
Old 08-13-2015, 12:42 PM   #10
In regard to emf interference, I had replaced some bulbs with cheap leds from Amazon. I thought they worked well and they do except when we were watching tv from our antenna one night with a weak signal. Every time we turned on a led light, the tv would stop working (signal issue, not power). Turn light off, picture came back. Did not happen with the conventional bulbs we still had and it was never a problem when on cable. Just an observation.
TSman is offline   Reply With Quote
light
