Old 07-31-2016, 11:24 PM   #21
Broadway Joe's Avatar
Originally Posted by Wxbee View Post
Hello all, just got a 2016 Wildwood 27RKSS as well! I went in to get some parts for my Grand Surveyor and walked out with a Wildwood!! Couldn't pass up the deal. However the sales staff was pretty much useless!!
Couple quick questions.. 1) is there a battery disconnect? 2) anyone figure out how to hack in the remote for awning.. Ect. and do it with your phone or iPad??
Sent from my SM-G930P using Tapatalk
It is not furnished with a battery disconnect, you will need to install one yourself if you require one.
As for the awning, mine came with a remote whose password is 0000
which brings up a screen for the awning, led lights under the awning and front and rear electric stabilizers.
Hope this helps
Joe
Joe
2015 Wildwood 27RKSS
2015 Silverado 2500HD Duramax
Broadway Joe is offline   Reply With Quote
Old 08-01-2016, 04:46 AM   #22
Wxbee's Avatar
I knew that salesman was full of it!! Here said there was one just couldn't find it!!
As far as the remote I was hoping someone had an IT degree and could figure out how to control with your iPad??
Wxbee is offline   Reply With Quote
Old 08-01-2016, 03:51 PM   #23
Head Rambler
Which remote do you have?
Most common of those remotes use RF (radio Frequency) not WiFi, so it'd take a WiFi to RF transmitter programmed to the right protocol and frequency. There's not enough demand to make it worth anyone's while to develop one.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-01-2016, 04:28 PM   #24
Wxbee's Avatar
Ahhh gotcha! Well that makes sense. Thx for the reply!!
Old 08-02-2016, 05:57 PM   #25
Wa11y757's Avatar
There is another topic on here about new 27rkss owner. On there , I posted a pic of my cut off switch. Easy install too.
Now I'm going back to looking for my 10mm wrench! 2016 Wildwood 27RKSS
2005 F250 PSD
Wa11y757 is offline   Reply With Quote
Old 08-02-2016, 05:59 PM   #26
Wxbee's Avatar
Great Thx man!
Old 08-03-2016, 04:33 AM   #27
Wa11y757's Avatar
No prob, any time.
Old 08-09-2016, 09:22 PM   #28
27RKSS
We bought this exact camper last year. It's a 2016 model. Get the bathroom door fixed. Ours still doesn't close. One of the bathroom cabinet doors is warped and we didn't get that fixed either. Our furniture does match however and I can't understand why they'd send a camper with different color furniture. You might want to fight for that one. Our DVD player would not play through our TV, so today I took it off the wall and would you believe the factory had put the cables in the AV IN slots instead of AV OUT? I changed them and now the DVD plays through the TV and camper speakers. We pull ours with a 2015 Silverado 1500 and have a little trouble on windy days but for the most part have no trouble pulling it. If you have any questions about your hot water heater, because of this forum, I am now an expert (ha) on this hot water heater. I've learned more this week about my camper from these great folks on this forum than I've known since I bought it last October. Great camping to you and your wife.
Lodie is offline   Reply With Quote
Old 08-09-2016, 09:31 PM   #29
Originally Posted by cartwrna View Post
Just got my 27RKSS home. I asked them about a W/D hitch and they ended up having a used one that had came in with a unit 10k Max and 1k Max TW, also has sway control. Ended up getting it for $100 which was nice. Found a few small issues on walk through they are correcting. A few bulbs were bad, and the exterior decals had bubbles in them where they were poorly attached so they are ordering me a new set. Can't wait to take it out next weekend! Had a hell of a time getting the hitch safety to release from the ball when I got home, a little WD40 and messing with it and she finally came loose
The new locking mechanism FR is using is a cheap Chinese POS. Several threads complaining about them. We had troubles the first few times. What we figured out that seems to work: I stand on my WDH and bounce a little while the DW extends the hitch jack. Haven't had any problems since we've been doing that.
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 08-23-2016, 11:08 PM   #30
How much of a drop do you recommend for hitch? Mine is a 3.5" drop or 1.5" rise. Not sure if I need to pick up something else to throw my ball on.
Congrats on the new tt. As for the hitch, I doubt the dealership explained how to make sure the hitch is set up for your exact vehicle. If it's not adjusted correctly, the tt won't pull as good or smoothly as it should. And, these adjustments can change with every vehicle used to pull the tt. For complete setup of an equalizer hitch and Sway bar system, go to davidsrvtips.blogspot.com, and search "hitch setup." He does a great job explaining how to make your hitch system work correctly with your tow vehicle.
Or maybe this explanation is on this forum as well. I didn't look here, as I found it there before I joined this forum.
WildAggie is offline   Reply With Quote
