Old 08-24-2016, 10:13 AM   #31
rracer5's Avatar
The way I used to do it is this; 1- Park & chock the TT wheels and unlock & release your coupler, - Extend your tongue jack until the rear of your TV is slightly higher than it normally is if the TT were not connected, 3- Disconnect your cord, safety chains, WD bars etc. (sometimes the ball will drop out of the coupler on its own), 4- If the ball doesn't drop out, now back the TV up about an inch or so. This should drop the ball out of the coupler without the extra physical exertion of prying or jumping on the ball/coupler assembly. 👍
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 08-24-2016, 02:56 PM   #32
Originally Posted by rracer5 View Post
The way I used to do it is this; 1- Park & chock the TT wheels and unlock & release your coupler, - Extend your tongue jack until the rear of your TV is slightly higher than it normally is if the TT were not connected, 3- Disconnect your cord, safety chains, WD bars etc. (sometimes the ball will drop out of the coupler on its own), 4- If the ball doesn't drop out, now back the TV up about an inch or so. This should drop the ball out of the coupler without the extra physical exertion of prying or jumping on the ball/coupler assembly. ��
If you've got the old style most of us are used to, like this one, this method will probably work.
But if you have one of these, which FR seems to have started using sometime between 2013 and 2016, it most likely will never "drop out on its own." At least that's been my experience.
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 08-24-2016, 06:45 PM   #33
Congrats on the new trailer's! I highly recommend adding airbags to your TV if you are towing with a 1/2 ton truck. It helps tremendously with sway.
RFM27tdss is offline   Reply With Quote
Old 08-24-2016, 09:24 PM   #34
rracer5's Avatar
That's exactly what I had on my 2011 LaCrosse and 8 or 9 times out of 10, I had to back up after raising trailer tongue.
2014 Sanibel 3250
