Old 03-22-2014, 09:14 PM   #1
New camper owner towing ?'s
Hi everyone. I have enjoyed reading of the posts and information shared on here. I have a question, we just purchased a 2014 wildwood X-lite 29' long with a dry weight of 4380 lb. going to pull it with a 2011 Nissan Frontier 4x4 crew cab. 6100 tow capacity. Any successes or troubles to foresee with this combination? Grateful for any help.
Punxsy1994 is offline   Reply With Quote
Old 03-22-2014, 10:54 PM   #2
Oklahoma Proud
MillerTime's Avatar
Congrats!
Don't know much about frontiers, but these trailers catch alot of wind and thats a little truck ( and a decent sized trailer).
Around town it will probably be fine, but maintaining speed on a highway might be a challenge, even on flats. I had a little truck once, handled weights fine, but any kind of wind resistance was a killer, just kept grabbing lower gears to " creep on going".
Hope it works ok for you!
Maybe they have bigger motors than i think in them, or a supercharger or sompthin!
Happy campin!!!
MillerTime- Future Sabre Handler!!
Old 03-23-2014, 06:10 AM   #3
davel1971's Avatar
phew, that might be a bit of a struggle. Since you will easily be over 5000lbs loaded, plus family and gear in truck, you will probably find yourself needing more power. That small of a truck could sure put you in some white knuckle driving situations too.
David & Lynn
Old 03-23-2014, 06:51 AM   #4
Engineer of Crazy Train
ChooChooMan74's Avatar
Before answering a question like this, I like to do a little research and compare it to what I am using, since I am one of the smaller rigs here.
1st, I looked at the truck. I am assuming that you have the 4.0 V6. That puts out 281 ft*lbs at 4000 RPM. Now, my engine with 335 ft*lbs at 2000 RPMs can maintain 60 on grades with my 4400 pound trailer.
2nd, 29 feet is a lot of trailer to catch the wind. Before buying my latest trailer (I owned when I was younger, but got away from it), I rented to see if the girlfriend and daughter would like it. That rental was 24 feet and with just a standard Weight Distribution Hitch, I was blown around by every bus and truck that passed. My trailer now is 22 feet with a high quality WDH, and now I can feel it, but I am in control.
One mistake you made is talking dry weight. You don't use an empty trailer. You will probably weigh in around 5500 lbs with 600 to 750 lbs of tongue weight.
I see you already made the purchase. All I can say now is hope you have a real high quality WDH, like the reese dual cam staitline or the equal-i-zer 4p because if you will be doing highway speeds (55 to 60 max!) you WILL need it. And, your tires will need to be upgraded to LT tires. P rated tires will make you feel like you're towing on marshmallows. I admit, I upgraded to P XL tires and it is way better than stock, I wish I upgraded to LT. I was just having issues finding LT in my wider than stock tire size that I wanted.
Sent from my Samsung Galaxy Note 2 using the FRF mobile app.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 03-23-2014, 08:36 AM   #5
Thanks everyone. I will try to upgrade tires and until I can upgrade truck, will stay at local (1-2hour ) trips. May even have the family take the minivan separate.
Old 03-23-2014, 08:42 AM   #6
davel1971's Avatar
good plan. Remember, its all about safety, not just of you and your family, but of everyone around you on the road also. Putting the family and as much gear as possible in the minivan would sure help your situation.
David & Lynn
Old 03-23-2014, 08:46 AM   #7
Ford Idaho's Avatar
This would be a good option as long as the van carries some of the load in the food or gear dept.
Old 04-07-2014, 09:40 PM   #8
Well, I made the 50 mile trip with the frontier. My family followed behind as my "spotters." The truck handled the hills ok, it worked like a champ. I would not do it again though. The wind had its way with me twice, but my truck kept on chugging. We have the trailer parked at a site for the next five weeks. I am looking to upgrade my tow vehicle. Any suggestions? It would have to be used. What would be a good fit for a family of 5, with a 29' travel trailer, approx. 4900#'s, tongue wt. 434lbs.? Thanks everyone.
Old 04-07-2014, 10:04 PM   #9
Taranwanderer's Avatar
You'll get all sorts of opinions on tow rigs on here...I'll save that for others. What I do have is a 4-PT Equalizer WDH for sale. By your name, I'm assuming you're in PA as well? PM if interested, I can give you the details.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 04-07-2014, 10:07 PM   #10
rracer5's Avatar
No less than a half ton Crew Cab, largest motor it comes with and no higher than 3.73 gear ratio (4.10 would be better).
I had a 2001 Chevy 1500HD CC with a 6.0 gas motor and towed a 34' Lacrosse weighing in about 9,000 lbs for 2 1/2 years with no issues. Of course, my Reese Dual Cam WD/Sway control hitch was a major part of driving stability.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
camper, towing
