Old 05-07-2014, 09:06 AM   #31
Originally Posted by Kaadk View Post
What's a payment book?
Last one I had was when I bought my new 81 El Camino and it had 36 pages@$81.24.
Old 05-07-2014, 09:59 AM   #32
I got the sewer hose, power cable, and power adapter. That's it.
TV: 2016 Ram 3500 4x4 mega cab w/6.7l Cummins
Trailer: 2013 Palomino Puma 27SBU
bitNine is offline   Reply With Quote
Old 05-07-2014, 10:32 AM   #33
Thanks everyone! I pick it up yesterday and made the 7hr drive home. Did well. I got a box with a sewer hose, TP, brass regulator and some sanitizer for the tank. So not bad. They said they were going to de-winterize it but I looked and it still has the red anti-freeze in it. So I am going to do it myself. I looked in the manual and it seems pretty easy. Drain the holding tanks, fill fresh water tank, turn on pump, let it run through the pipes and then drain tanks.
I ran into this issue. There is a nozzle in the front by one of the tanks and beside the nozzle is a hose. I closed the nozzle and tried to fill the tank up and about 6 min later the minitor was still indicating that the tank is empty. Then the hose beside the nozzle started to expel water. So I thought it was overflowing or something so I opened the nozzle as in the picture to allow it to drain faster.
So what am I doing wrong? I can't seem to fill the fresh water tank without that hose part draining.
Fahmain is offline   Reply With Quote
Old 05-07-2014, 01:35 PM   #34
So addition to not being able to get the pump to work, or the sensors in the tank to work, the toilet is leaking. Possibly a broken toilet valve. Great!
Old 05-07-2014, 02:48 PM   #35
BamaBob's Avatar
*Gulp* I hate to ask at this point, but did you take a PDI checklist with you? [there is one in the library: Forest River Forums - Downloads - PDI Checklist]
When I read your previous post about not letting the dealer dewinterize I kinda winced and hoped that your plumbing system(s) would function correctly.
At this point, I recommend you call the dealer and explain the situation; be prepared to make a return trip to the dealer with TT in tow.
Please keep us posted
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is offline   Reply With Quote
Old 05-08-2014, 07:13 AM   #36
Yeah I didn't have time to go over it all as we live 7 hrs away and were leaving asap. I think the toilet issue is a simple fix that I can do which I am going to call and see if they allow it most likely is a metal strap that just needs to be replaced and tightened. And I think the pump issue might be because the valves are closed I believe. I'll keep you guys updated. Other than those 2 issues. The trailer is great.
Old 05-08-2014, 08:34 AM   #37
PPST OGCDG
Frank-VA's Avatar
That hose is suppose to be the over flow.
The Hose with the Valve is the Drain
Frank- VA {:-{)
2004 4x4 Ford 6.0 PS, SCC, SB
2005 Wildcat 29 RLBS
Frank-VA is offline   Reply With Quote
Old 05-08-2014, 09:16 AM   #38
Yeah, I filled it up for a good 8 minutes and kept checking the monitor. It kept saying empty. Even when the overflow was pouring water out.
Old 05-08-2014, 09:19 AM   #39
Kaadk's Avatar
I remember running across a thread last year about a situation like that. The overflow was causing a siphon effect and no water was staying in the tank. I don't remember what the resolution was though but I think it ultimately ended up going back to the dealer and having them fix it.
There's no use crying over spilt milk, unless it's on your keyboard.
Kaadk is online now   Reply With Quote
Old 05-08-2014, 09:20 AM   #40
I think that is going to have to be the plan.
camper
