You probably have the Everchill 12v DC only fridge, which is a recent fridge option. You should be able to download the manual, if you get the model number.
You need to check your 7-pin connector and see if the charging wire is supplying juice.
As far as I know, Wildwoods don't have a factory battery disconnect switches, like other brands do. So you'll have to install your own. Thousands of posts here on that.
