06-19-2019, 03:08 AM
New Tires...How often to rotate?
We got new tires on our travel trailer in March. We are just weekenders. How often do we need to rotate the tires on our camper? How many miles traveled between rotations? Your input is greatly appreciated in advance!! Thanks!!!
06-19-2019, 06:18 AM
Never. They will age out long before they wear out.
I have owned campers since 1985, currently own 3 two axle trailers. At 5 years (aged out ) the tread always looks great but the tires should be replaced. If they show unusual wear the axle is probably out of alignment. I have never rotated trailer tires.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
06-19-2019, 06:24 AM
Insert witty title here
All my tires do a full rotation once about 5 feet of travel.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
06-19-2019, 07:43 AM
Normally, no need to rotate RV trailer tires as you do passenger vehicles. No steer tires.
Enjoy RVing!!!!
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
06-19-2019, 08:02 AM
Camper
That's funny.
I have never rotated my trailer tires. If you are full timing then it would be a good idea.
Thanks,
Brian
TV - 2006 F350 6.0 DRW CC
TT - 2018 Wildwood 31KQBTS
06-19-2019, 11:45 AM
I read somewhere that if they sit for long they can get flat spots on them. That’s why I asked about rotating. We only use our camper about 5-7 times a year during summer months.
06-19-2019, 11:52 AM
Flat spots disappear after a mile or so when the tires warm up while "driving".
Most people start out on roads with low speed limits so they should "de-flat spot" well before hitting the freeway.
As for rotating to different positions, nothing to gain. If you have strange tire wear develop, get it to a shop and get the problem fixed. Rotation won't help.
Use your camper more often...
Do not need to rotate front to back or side to side
2014 Shamrock 183
06-19-2019, 12:26 PM
Repack bearings at 5k miles or once a year, which ever comes first. Use trip mileage reading on tv for each trip to keep running total. Since I have tires off to repack bearings, rotate front to back. My thinking is, I know there is a slight load in balance between axles even with my Blue Ox WD bars.
2020 Georgetown 31L, Safe T steering, Sumo springs, Onan Geny
2015 GMC Canyon 4X4 TOAD w/Blue Ox tow plates, InvisiBrake
Pepper 🌶 PomChi rescue 545 nights as our camping buddy
Days camped in FR 2011-12 = 77, 13-14 = 98, 15-16 = 129
17 = 81, 18 = 44, 19 = 83, 20= 45, 21 = 76, 22 = 57, 23 = 42
Retired :
06-19-2019, 12:44 PM
I put my spare on once a year, Keep track of which tire you switched, so the next year you switch with the other tire.
OCD I guess?
Cheers
06-19-2019, 01:35 PM
I never have rotated. Only once did a tire appear to wear unevenly, so the remedy was to find out why and not rotate. The why was a slightly bent rim.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
06-19-2019, 05:42 PM
Agree with those who propose rotating trailer tires is not needed. Unless there is a more serious problem with axle misalignment, then you will never notice any disparity in the tire wear patterns from tire to tire. If there is a discrepancy, then it is the result of poor misalignment, and should be corrected ASAP.
In 45+ years of RV-ing, we have never relied on mileage before changing out trailer tires. We change out at least every five years, except for the "China Bombs", which have lasted in some cases less than one year!! In the past 20+ years, we have insisted that every new RV purchase be equipped with tires made in the USA, or in France by Michelin (no longer available). So far, so good. Still have Michelins on our TV.
06-20-2019, 06:40 AM
Originally Posted by Macrosill
That's funny.
that went right over your head and never saw it
06-20-2019, 06:44 AM
flat spots will go away after towing a few miles
06-20-2019, 07:11 AM
Fonzie
06-20-2019, 07:48 AM
Originally Posted by fonzie
I would agree that 3 axle trailer tires should be rotated but not two axle.
I have never had tires wear out in 35 plus years of owning 2 or 3 trailers at a time with two axles. Mine have always aged out first. I currently own three two axle trailers all tires have like new tread never rotated tires.
1966 Mustang GT
1986 Mustang SVO
06-20-2019, 10:47 AM
OCD I guess?
Cheers
Sounds like a good idea to me !!!
06-20-2019, 10:56 AM
I have rotated mine a couple of times about every 10,000 miles. I have it completely level while towing but turning it likes to pivot on the front axle and scrub the back tires so I rotate to keep the wear even. I have never done this on any previous trailer but then I never put as many miles on as we have with this trailer.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
06-20-2019, 11:07 AM
No need to rotate. Some will get the wheels balanced but that's a waste because trailer drums can be very unbalanced and negate a balancing job at a shop. I know someone who spends the time to balance his TT wheels manually when their mounted on the TT, but you need to make some witness marks so it wheel and tire stay in the same relative positions.
On ST tires, make sure to follow these if you want good service life and to minimize the risk of a blowout:
- never tow overloaded.
- never tow under-inflated.
- never tow over the tire's speed rating.
Inflate the tires to max. sidewall psi. Periodically check pressure including on road trips.
Going to a scale is always highly recommended. Try and get the weight on each tire if at all possible because trailers can be heavier on one side or axle to axle. You want at least 15% reserve load capacity - the tire's load rating compared to actual weight on the tires. Tires can be okay based on total weight, but tires can sometimes be overloaded on one side (due to wt. of kitchen and/or slide.) Travelling with one or more full holding tanks can cause tires to be overloaded. Know your weights!
Oh, and don't keep ST tires past 5 years (based on date code) because they usually age out before they wear out.
Gil & Deb & Dougal the Springer Spaniel
Langley, BC
06-20-2019, 11:10 AM
Trailer tires are neither drive nor steer, so there is no need to rotate unless you just can't get it off your mind. Like said ... if you have tread wear, you have other issues like bad camber, too much toe in or out, or axles not square to the trailer or perpendicular to one another.
