Old 09-28-2014, 02:52 PM   #1
Newbie trying to figure out hot water heater
We just got a wildwood x lite 26bhxl- I have read people talking about bypass valves- where exactly would I find these valves? I'm super confused!
kampk is offline   Reply With Quote
Old 09-28-2014, 02:57 PM   #2
fonzie's Avatar
By-pass valves are usually behind water heater and accessible from inside trailer.....top picture summer position and bottom picture winter by-pass position
Fonzie
Old 09-28-2014, 03:40 PM   #3
Thank you!!
Old 09-28-2014, 09:24 PM   #4
Thekipkers's Avatar
You should have access to HW from the bottom bunk. Pull out mattress and unscrew decking
Thekipkers is offline   Reply With Quote
Old 10-01-2014, 09:23 PM   #5
BooBoo23's Avatar
You may have 3 valves or in my case there are 2 valves, one on the outlet of the hot water tank and a 2-way valve in the inlet. Some may only have 1 valve, being a 2-way on the inlet and a check valve on the outlet. The handle will line up with the flow of the water as they are only 1/4 turn so depending on how you where you want to have the water flow is how you turn the valve.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
BooBoo23 is offline   Reply With Quote
heater, hot water, newbie, water, water heater
