Since you have 12 colts when plugged in to the truck, probably not the circuit breaker on the tongue. Since you have 12 volts when on shore power, probably not the converter or fuse. Since you have no 12 volts while on battery only, I would suspect the battery itself. Won't hols any type of charge. Get a meter and check it. If you get 12 volts, turn on a couple of lights and check again. Keep us posted.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
