Old 11-18-2012, 08:43 AM   #1
No Heat
I went out to my Camper yesterday and started the Furnace up the Furnace came on and would work for about 4 minutes blowing heat and then it would start blowing cold air. I have plenty propane and it doesn't quit all together
like a circuit breaker would do.
Any thoughts?
Norm
2005- WDF27RLSS
2001-Dodge-4/4- souped up Cummins
1953 Willys 4/4
1970 Restored Cushman Trackster
Olratlr is offline   Reply With Quote
Old 11-18-2012, 10:23 AM   #2
Dave_Monica's Avatar
Were the propane tank valves closed and you opened them and if so, did you open the tank valves very slowly? Have you tried lighting a stove burner to confirm propane flow?
Dave
Old 11-18-2012, 11:43 AM   #3
The stove works fine and if I start the stove again the heat will come back on
for about 4 minutes.
2005- WDF27RLSS
1953 Willys 4/4
Old 11-18-2012, 11:48 AM   #4
Try turning the tanks off completely and then VERY, VERY slowly open them. There is a safety valve that if the tanks are opened very fast, they will close down the flow rate or sometimes completely.
Old 11-18-2012, 12:14 PM   #5
Witch Doctor's Avatar
Any thoughts?
Norm
I would check the stat first, the location could be a problem also turn it up like 10 degrees and see if it will stay on. these junk thermostats are very inaccurate ...
Old 11-18-2012, 01:01 PM   #6
I tried that Furnace came on blowed hot air about 4 min again.
I relit stove and turned Furnace back on and furnace came on and stove went out.???
The second time the stove didn't go out.
2005- WDF27RLSS
1953 Willys 4/4
Old 11-18-2012, 01:13 PM   #7
Did you try turning the gas off at the tanks and then turning them on again very slowly?
Old 11-18-2012, 01:19 PM   #8
Yes I did.
2005- WDF27RLSS
1953 Willys 4/4
Old 11-18-2012, 01:21 PM   #9
I'm sure you have both tanks open if you have two? If still a problem sounds like your regulator is restricting the flow needed.You need 11.5" of pressure......It's just a guess !!!!!!!!
Old 11-18-2012, 01:27 PM   #10
Thanks! I have one full tank and one empty I think the regulator is to blame
when the stove went out when turning the furnace on.
2005- WDF27RLSS
1953 Willys 4/4
