Old 05-22-2016, 01:55 PM   #11
Gatch's Avatar
I always run the slides out first then level the rig. Seems to work for me.
Gatch is offline   Reply With Quote
Old 05-22-2016, 02:36 PM   #12
Originally Posted by Timex View Post
Youroo, I've seen you post this dozens of times.
Just how did you get that big motorsickle up there on the high dive?
Its the Easyest way of all,wife places 1 ramp in front of tire and I pull up the needed amount to become level when the 2nd ramp is placed behind the other tire! We know the amount of ramp we need every time IF the site is Level,if the Site is LOW we just add that amount into the additional Up Ramp needed! The unit is "Chocked Also" at the finish! Youroo!!
Old 05-22-2016, 02:40 PM   #13
Timex's Avatar
I was just goosing you until you'd give us a caption.
Thanks for the info.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 05-22-2016, 02:44 PM   #14
273QBXL=27' 3" quen bed Xtra Large Slide (For those of us that haven't memorized the alphabet soup of RV's, exactly what is a 273QBXL? It would sure help and save some of us time if you gave a brief description on your RV in your initial post. Thanks in advance!!!!)
pbandrb is offline   Reply With Quote
Old 05-22-2016, 02:46 PM   #15
Originally Posted by lbrjet View Post
Let me guess. You got the trailer level, put the slides out and went about your other tasks. Go inside and think it seems like the slide side is a little low, but not too bad. The next day seems worse, but in reality probably hasn't changed much if at all. As others have said the solution is to keep the slide side an inch or two high when 'leveling'. Put out your slides and you will be good to go.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
the lean or out of level does not happen when parked on concrete driveway just when we camp it has happened 2 out of 3 times
Old 05-22-2016, 02:59 PM   #16
Then your driveway is NOT Level! Youroo!!
Old 05-22-2016, 03:08 PM   #17
that is true driveway not level i use level on countertop after using ramps to level and it stays level for weeks with us in and out every few days in between camping trips.
Old 05-22-2016, 03:13 PM   #18
I have the same trailer and mine leans on the slide side also. Guess I will try to raise it so it will level out
Joe5988 is offline   Reply With Quote
Old 05-22-2016, 03:28 PM   #19
I only have two trips on mine but have now found the right method to the madness. (with help from FRF and practice at home)
Set were you would like to stay, adjust with blocks under tires to get about 1/4 bubble high on the slide side, level front to rear, set the stabilizers down firmly, extend slides.
That seemed to work perfect on the last trip which was on a gravel pad.
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
Old 05-22-2016, 03:40 PM   #20
nice recomendation, i will try this before purchasing slide stabilizer's
