Old 06-02-2016, 12:29 PM   #41
D_B Travelers's Avatar
Graduated level
With the 3001w Windjammer both slides are on one side and both extend out 39", so there is quite a weight shift when they are pushed out. We bought a small (12") level with a graduated bubble glass that designates 1/8", 1/4", etc. high per foot right on the glass. It is magnetic so I set it on the back bumper when setting up. We set up higher on the slide side, with slides in, at 1/4" high or slightly less, then put down the electric stabilizers and then extend the slides. The TT settles down the second day to about half way between "0" and 1/8" high on the slide side which works fine for us; bathroom door stays open without a prop. After a couple of days the TT is at "0". I use the X-chocks between the wheels and do have to tighten the stabilizers every day or so also. Not a big deal, works every time and surface, and the DW and I have setting it up this way down pat.
D_B Travelers - 8 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 1996)
D_B Travelers is offline   Reply With Quote
Old 06-02-2016, 02:18 PM   #42
Originally Posted by pbandrb View Post
273QBXL on day 2 becomes unlevel it dips on slide side which is side that has love seat and dinette, i have electric stablizers and bump them every day just not help, both trips were gravel. i am think slide stablizers might help. i would enjoy hearing coments from other members.
Before I put slides out I place 4' level on bumper and put the slide side about a 1/4 bubble high. We run slide out it will end up just a little high on slide side.
Myrle is offline   Reply With Quote
Old 06-02-2016, 05:24 PM   #43
thanks for all the replies and tips, i will try the 1/4 bubble trick
pbandrb is offline   Reply With Quote
Old 06-02-2016, 06:13 PM   #44
Youroo,
Where did you get those black tire chocks, levelers that are in your picture?
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
txredfish is offline   Reply With Quote
Old 06-02-2016, 06:33 PM   #45
Originally Posted by txredfish View Post
Youroo,
Harbor Freight part # 67722, 16000# per set, 45.00$ Youroo!!
youroo is online now   Reply With Quote
Old 06-02-2016, 06:37 PM   #46
These! Youroo!! They are "Made in the USA"!
Old 06-02-2016, 07:24 PM   #47
Timex's Avatar
You couldn't help it could you?
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 06-03-2016, 08:54 AM   #48
ilmor's Avatar
I always put an extra inch of leveler on the slide side. After everything settles (springs, tires, ground) it's perfect.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 06-03-2016, 09:31 AM   #49
I use supports, a little pricy but works great.
Vimax is offline   Reply With Quote
Old 06-03-2016, 12:37 PM   #50
Leveling 5th wheel
I had a 6 point leveling system by Lippert Components installed on my RV about a year ago. I have been in about 25 different parks since then. I simply park where I want to. Disconnect the 5th from the truck and push the auto level button. After about a minute it beeps and it is perfect. With the large diameter base on the legs and most of the weight not on the tires, I have never noticed a sag regardless of base. I also have opposing slides.
jacknel is offline   Reply With Quote
