Old 03-24-2015, 05:27 PM   #1
odd leak
OK, We have an odd problem.
We have a 2015 Forest River Wildwood 30QBSS.
The connection for the cold water line to the kitchen sink leaks. Now, it only leaks when the shower is in use. I've taken the fitting off and replaced the rubber compression ring/gasket, but it still leaks when the shower is running. We have a bread pan catching the water and it will stay dry until someone showers then it dumps about 1/4 inch of water into the pan.
I'm so confused. We have tried running the bathroom sink both hot and cold, nothing. Run the shower Bam! Water in the pan.
Tow vehicle:
Need to buy one.
RV:
1983 Holiday Rambler Imperial 33
IHalterman is offline   Reply With Quote
Old 03-24-2015, 11:28 PM   #2
dsjohns71's Avatar
Sounds like maybe a backflow issue??
dsjohns71 is offline   Reply With Quote
Old 03-25-2015, 01:56 AM   #3
Just a member
kandl's Avatar
You don't say but we have to wonder why you're trying to fix something that is very likely covered under warranty?
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 03-25-2015, 08:32 AM   #4
odd leak
Smh.......
Maybe he didnt want to deal with the stealership over a simple fix. Or a long drive. Thats his business....
kevnky is offline   Reply With Quote
Old 03-25-2015, 08:53 AM   #5
geotex1's Avatar
Flair-It fitting from PEX to 1/2" thread for faucet? If so, leaking from threads?
geotex1 is offline   Reply With Quote
leak
