Old 01-04-2018, 05:44 PM   #1
Outdoor Kitchen Drain
We have a 2017 356QB and recently discovered our outdoor kitchen sink is not draining. We have researched and traced pipes and cannot find a solution to the problem. Anyone have any ideas? The sink fills up and water runs out of the slide and into the rear bedroom. Please help!!
lmcgolf06 is offline   Reply With Quote
Old 01-04-2018, 06:14 PM   #2
Carknocker Family
Ida Ratherbe Camping's Avatar
Have you checked p trap to make sure not clogged? Our outside kitchen has a taped up cover under sink. Remove that and on ours, just goes to rear tank after trap. About o foot of plumbing total.
You say it's running into slide? Is this after the sink over flows and spreads everywhere or water slowly drains and ends up in slide.
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
Ida Ratherbe Camping is offline   Reply With Quote
Old 01-04-2018, 06:44 PM   #3
gpaw56's Avatar
Don't have that model but ours has outdoor sink and it has a tank and drain valve on its own.
gpaw56 is offline   Reply With Quote
Old 01-04-2018, 07:14 PM   #4
After sink overflows. We had to disconnect the pipe from the sink for it to drain.
Old 01-04-2018, 07:25 PM   #5
My outdoor kitchen drains into black tank.
Rdeejr is online now   Reply With Quote
Old 01-04-2018, 07:50 PM   #6
x2 previous rig. Short pipe run as also noted above.
Regarding the P trap, not sure if you can see the p trap but some use this horizontal p trap equivalent. Hepvo Waterless Valve
Can't use snakes, etc to clean it as they will destroy the valve
2016 RAM 3500 DRW 4x4 LB LoneStar Edition, w/Timbrens, Andersen Ultimate 2, Swift Hitch SH04 WiFi Backup/Rear View Camera
2018 Chaparral 360IBL w/Tireminder SMART TPMS, Furrion Wireless Observation System, Progressive EMS-HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
Old 01-05-2018, 06:49 AM   #7
Since mine drains into black I purchased this to attach drain to a water hose. Click image for larger version
Old 01-15-2018, 08:17 PM   #8
Tfort's Avatar
I have the same rig and have not a problem with it draining except when the little plastic sink strainer screws itself back in and plugs the sink. It should have the waterless trap on it that my be plugged or malfunctioning.
Tfort is offline   Reply With Quote
Old 02-19-2018, 08:26 PM   #9
schwabml's Avatar
My 356qb plumbing cracked on the outdoor kitchen and had to be replaced under warranty. Some how the bracket that holds it to the slide and pulls it out broke and so it wasnít sliding out as intended. This put strain on the pipe and twisted the drain at the sink, cracked the pipe, and leaks from the pipe and sink drain.
schwabml is offline   Reply With Quote
door, drain, outdoor kitchen
