Old 01-18-2018, 10:14 PM   #1
Outdoor Speakers - Who makes a replacement?
My outdoor speakers have failed due to exposure and I can't find a replacement. Everything I can find is either the wrong diameter or too deep to install.
It had a pair of RVtion 662-b speakers but I can't find those or any supper low profile speakers.
The speaker I have is called a 6" but I think they should say 6.5"
Thanks for the help
speedfast is offline   Reply With Quote
Old 01-18-2018, 10:17 PM   #2
Nurek's Avatar
Maybe you can visit your local car audio retailer and see if they can set you up with something better which will sound better and last longer.
2011 Nissan Xterra V6
2016 Rockwood MiniLite 2306
Nights Camped 2016 [24]
Nights Camped 2017 [63]
Nights Camped 2018 [27]
Nurek is offline   Reply With Quote
Old 01-19-2018, 07:27 AM   #3
Camper
I doubt you will find those exact speakers anywhere other than a salvage yard. I think you would be better off replacing them with another brand. Amazon has a lot of 6.5" marine speakers. Here is one example. In the review someone states they installed them on the outside wall of their RV.
https://www.amazon.com/Alpine-SPS-M6...2&keywords=6.5
Make sure to check the installation depth. The distance between the mounting surface and the base of the magnet to make sure it will fit inside the wall.
Thanks,
Brian
TV - 2006 F350 6.0 DRW CC
TT - 2018 Wildwood 31KQBTS
Macrosill is offline   Reply With Quote
Old 01-19-2018, 09:16 AM   #4
Crutchfield has been in business for a long time and might have something that fits.
https://www.crutchfield.com/S-v2sV4t...-Speakers.html
Old 01-19-2018, 01:55 PM   #5
MilCop4523's Avatar
whatever you purchase ensure they are WATERPROOF!.
Jensen makes good marine grade speakers which I installed on our BH 2 yrs ago. we had blasted the center cones out of the factory units which were 5 inch ones and I had to open the mounting hole out a bit more for these.
Site: JENSEN Speakers
Speakers: Outdoor Speakers | MSX60RV 6.5 in. JENSEN Coaxial Outdoor Speakers
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
Old 01-19-2018, 02:26 PM   #6
May we never camp close to each other. Not a fan of others music. It’ just me
pdqparalegal1 is offline   Reply With Quote
Old 01-19-2018, 02:36 PM   #7
510Rick's Avatar
Thats the very reason I dont camp in parking lots .
TV:GMC 2500HD Duramax
TT: 2015 Wildwood 21rbs
510Rick is offline   Reply With Quote
Old 01-19-2018, 02:38 PM   #8
Overtons carries good marine speakers which are what you need
twiggw is offline   Reply With Quote
Old 01-19-2018, 05:04 PM   #9
We use a small boom box. Bluetooth, usb, micro sd card, aux, am, fm, rechargeable. We can use it at the table or take it to the campfire with you. Sounds great at any volume so you do not bother your neighbors.
markb422 is offline   Reply With Quote
Old 01-19-2018, 08:04 PM   #10
X2 Dont camp near me. Birds chirping is all I want to hear.
milton_w_herron is offline   Reply With Quote
Old 01-19-2018, 09:02 PM   #11
crunchman12001's Avatar
Wow, the OP asked about new speakers to fit his setup, NOT your opinion on what YOU feel YOU should experience at a campground.
2015 F-250 FX4
Old 01-19-2018, 09:11 PM   #12
Here is the phone number. Give them a call.
China Rvtion Group
Arcadia - Electronic Parts and Equipment Companies
http://listings.findthecompany.com/l...a-Rvtion-Group
2015 F-250 FX4
Old 01-20-2018, 07:51 AM   #13
Well said!!!
Jwag1701
2015 2500HD
2015 Rockwood Signature ultra lite 8310
jwagner1701 is offline   Reply With Quote
Old 01-20-2018, 09:44 AM   #14
rearly7's Avatar
We upgraded the exterior speakers to the Fusion Marine speakers. Not for the volume... But for the clarity. http://www.forestriverforums.com/for...d.php?t=131555
rearly7 is offline   Reply With Quote
Old 01-20-2018, 01:30 PM   #15
I'm not sure what speakers you are looking for, but most RV dealers should be able to get replacement speakers for you. My RV Dealer, Madison RV, Madison, AL has several different speakers in stock.
As to outside music, I don't turn my volume up high enough to disturb my neighbors.
tomrob1161 is offline   Reply With Quote
Old 05-08-2018, 09:08 PM   #16
Locky's Avatar
Speedfast, did you ever get a chance to replace your outdoor speakers?
2018 Rockwood 2906WS
2015 GMC Sierra
1967 Beautiful Wife
Locky is offline   Reply With Quote
Old 07-24-2019, 10:45 AM   #17
I know this is an old thread, but if anyone else is looking, Pyle makes a shallow speaker, available on Amazon that should work (the one I ordered was approx. 1.5" deep). On our Sierra I replaced our outside speakers with the 5.5" 100W 4ohm water proof version. Screw holes were even an exact match with the originals. One thing to note is make sure you order the right size. The complete outer diameter of our speakers was a hair over 6". This is NOT your speaker size. Ours were 5.5" speakers. I had to do a very small amount of work with a carbide burr in a rotary tool to fit them in (about 5 minutes each side). Make sure to have a N95 mask handy if you are going to do this. Last piece of advice, is to take note of which wire is connected to the pos vs neg terminal on original speaker so you don't mix them up. Hope this helps others, and everyone needs to be respectful of those around them. We mainly use ours when camping in isolated locations or at the ball tourney's and that's about it.
trev.mlt is offline   Reply With Quote
Old 07-24-2019, 06:56 PM   #18
trev.mlt,
Thank you for reply. Do you have a model # on those Pyle speakers? I ended up buying a Klipsch Groove bluetooth speaker. It sounds much better that the OEM.
Thanks again,
crunchman
2015 F-250 FX4
Old 08-01-2019, 02:04 PM   #19
I'm not sure if they're the same model mentioned above but I replaced mine with these Pyle PLMR51B. They fit perfectly without modification in the wholes from oem speakers.
mdarmody is offline   Reply With Quote
door, replacement
