Old 08-26-2014, 07:14 PM   #1
Outside TV mount
Does anyone know where I can get another mount to hang a larger tv outside on the existing mount without removing indoor the tv. I've looked on eBay, amazon and camping world. Wanting to hang a 40" for tailgating and leave inside one alone.
locomotivejoe is offline   Reply With Quote
Old 08-26-2014, 07:41 PM   #2
vinmaker's Avatar
I think since you are starting from scratch ( meaning you will be leaving the inside alone) your options are limitless. I would recommend buying a TV that can be mounted and then buy an approriate mount for the TV. Then you just need to figure out how you want to mount it to the trailer. The outside already has the plug so you are good to go. You could also install a cable jack on the outside if you want one of those too. Life is good.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 08-26-2014, 07:57 PM   #3
I already have the bracket installed from the factory outside. I really don't want to start over with a different kind. I want the tv part of the one that'll hang on the existing mount outside. Maybe directly from Forrest River?
Old 08-26-2014, 08:28 PM   #4
Jimandchris's Avatar
I've looked for that as well. Ended up fabricating the mount so i could hang a fan outside, but it doesn't articulate. It would be nice to have the option of buying just the tv side of the mount.
2014 Roo 23SS
2013 GM Sierra CC
Prodigy P3 Brake Controller
Equal-i-zer Hitch
Nites Camped 2016 -25
Jimandchris is offline   Reply With Quote
Old 08-26-2014, 09:06 PM   #5
Iwannacamp's Avatar
Is this it?
Majestic Wall Mount Brackets https://www.amazon.com/dp/B00JGX6ESO..._oZt.tb0W1S840
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 08-26-2014, 09:08 PM   #6
Iwannacamp's Avatar
Or this...
http://www.majestic-global.us/wall-b...armla55-3.html
2017 Puma 297RLSS
Old 08-26-2014, 09:09 PM   #7
Iwannacamp's Avatar
http://www.amazon.com/gp/aw/d/B003CQ...&robot_redir=1
2017 Puma 297RLSS
Old 08-26-2014, 09:11 PM   #8
Iwannacamp's Avatar
Cheaper...
http://www.defender.com/product.jsp?...863&id=2338817
2017 Puma 297RLSS
Old 08-28-2014, 06:53 AM   #9
Attaching a pic of the outside bracket. It isn't any of those types you've listed. Thanks for the help
Old 08-28-2014, 07:18 AM   #10
vinmaker's Avatar
Ok. I understand. Would it be possible for you to fabricate a plate between the two? Prepare a plate with holes that match the TP and holes that match the mounting bracket. You then bolt the plate to the TV and then bolt the plate (with TV attached) to the mounting bracket.
2015 HW296
2013 Chevy Tahoe
Equalizer WDH 1000#
mount, tv mount
