Old 10-22-2014, 02:50 PM   #21
mud yapster's Avatar
Or they may tell you where to take it to get it fixed.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 10-22-2014, 03:00 PM   #22
Brother Les's Avatar
The word...Lawsuit... should never come up in the conversation. (all communication will shut down if that word is use)
1) talk to Dealer owner on phone. Tell him his Rep said 'tire problem'.... Tell him that everyone else that you talked to said 'alignment' problem. Tell him you will not drive 7 hours and trust a bios 'rep', but will take to a local alignment shop for review. You will contact him after the review for reimbursement on the alignment and adjustment on the tires. If the Dealer wants Lippert involved.. YOU talk to Lippert for yourself and do not go through the Dealer.
(imo)
No words about Lawsuit.... (keep your cards covered)
Brother Les
Old 10-22-2014, 04:03 PM   #23
jawga's Avatar
thanks for the update, guess its new tires for me then also
jawga is offline   Reply With Quote
Old 10-22-2014, 04:56 PM   #24
Is this an issue ton specific models? Or all Wildwood/Forest River TT's?
VT Skier is offline   Reply With Quote
Old 10-22-2014, 07:37 PM   #25
Not fair to condemn the entire model line, could be small number of TTs.
roberttlh is offline   Reply With Quote
Old 10-22-2014, 09:03 PM   #26
Which model Wildwood do you have? I see two that could be cargo challenged. The 27RKSS and the 27RLSS. Loading both those to the max could cause problems. The rest of the lineup has what looks like more CCC than you could actually load in a TT.
If you only have 1200lbs or so of CCC then it is possible that you are overloaded.
goduc is offline   Reply With Quote
Old 10-23-2014, 10:55 AM   #27
252rlx model. Have never come close to overloading it.
Old 10-23-2014, 11:42 AM   #28
Have you looked underneath to see what axle you have? The GVW of that TT is 7648lbs. Assuming a minimum of 10% tongue weight would give you a fully loaded weight around 6883lbs. If they put two 3500lb axles under then you could be close on max load. Just a thought. I would hope they put 4400lb axles under it.
OK I found one like yours and it had a sticker of the axle and CCC sticker. You do have 3500lbs axles. The dry weight of the one on the net was 5700lbs. Not sure what yours weighs but since most people load 1000lbs in I'll go with that. 6700lbs and 10% for TW that leaves 6030lbs on the axles. 7000lbs for the axles leaves you with 242.5 per hub. I think that should be enough. But if they're lippert it's a good chance that they're using softer steel and they have in fact bent.
I would get it weighed camp ready and then see how far under the GVW you are. That will give you something to work with.
Old 10-23-2014, 11:44 AM   #29
vinmaker's Avatar
Not much more to add Robert.
I wish you luck and keep us posted on your efforts. Sounds like you have a good handle on what should be done.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 10000#
Old 10-23-2014, 11:49 AM   #30
Just bring it to a quality heavy duty truck/trailer alignment shop. They will fix the problem for under $200.00 and you can move on. Don't go to an RV dealer they are not equipped to do an alignment. All they will do is replace the axle with a new one which may be off as well. The popular Correct Track system won't do you any good either. All they do is adjust the axles tracking they cannot make adjustments for camber or toe. A good alignment shop can adjust all three.
GOTTOYS is offline   Reply With Quote
Old 10-23-2014, 11:59 AM   #31
Thanks for all the good advice, my axles are 3,700 pounds each. I will take it to an axle shop after I hit the public scales.
Old 10-23-2014, 12:09 PM   #32
TURBS's Avatar
Chart
Turbs
Old 10-23-2014, 12:36 PM   #33
I feel your pain. I went thru the same thing on a SOB TT. It really sucks to have to fix things that should never be a problem. Especially when you don't get support from the dealer. No brand is excluded from issues which is sad.
Old 10-23-2014, 01:27 PM   #34
I have a 2015 Salem 27RKSS that I just picked up. Maiden voyage this coming weekend. How do I tell if the axles are in upside down?
2015 Salem 27RKSS
2011 Dodge RAM 1500 Hemi 5.7
dirkpitt is offline   Reply With Quote
Old 10-23-2014, 02:02 PM   #35
They should have crown to them. Arched upward in the middle.
Old 10-23-2014, 02:04 PM   #36
Thanks goduc, I will check that once I get home.
2015 Salem 27RKSS
Old 10-23-2014, 06:58 PM   #37
I have never heard of an axle being installed upside down. This would be hard to do as the spring pads are welded to them and they will only only fit the springs one way.
Old 10-23-2014, 07:45 PM   #38
Read on these forums enough and you'll read about all kinds of stuff. I've only read about it a coupe times but then again of the 1000's of trailers sold only a small percentage ever posts on forums.
Old 01-01-2015, 10:59 AM   #39
Wa11y757's Avatar
Well, dealer called and said my single axle,195bh was done. Warranty water leak was roof,and some wall panels replaced. But, they said inside tire wear is normal at this time, 300 miles on unit. I was told, this time, that it has more than that because the factory tows it to the dealer, 1000 miles. When I purchased it, the dealer said small TT's get put on a flat bed 2 or 3 at a time and hauled to the dealer....hmmmm. Then I was advised to put radial tires on it. I'm not happy with the results.
The top tank level sensors do not work either, in the black or grey. The dealer said that "FR doesn't pay for diag time and the wiring tested good, at this time it doesn't appear to be a warranty issue, empty them when the 2/3". Seriously! That what I was told. I've had it 8 months, used it 6 times and they had for the last 2 months " waiting on parts from the factory".
Being an auto mechanic, and I the customer service field everyday, I find it amazing that a company is willing to loose a customer over 10 mins of labor and a $5 sensor.
Any thoughts? Anybody know of a factory phone number or point of contact?
2014 Wildwood X-lite 195bh......Happy camping.
Wa11y757 is offline   Reply With Quote
Old 01-01-2015, 11:09 AM   #40
Witch Doctor's Avatar
Check the library. You will find all the phone #'s and email address.
Coachmen M/H
Concord
2018 / 300 DSC
2014, tire, wildwood
