Old 07-07-2016, 01:52 PM   #11
Originally Posted by Jack L View Post
I was hoping that someone with the same trailer could give me the answers.
Jack L
http://www.forestriverinc.com/brochu...orbrochure.pdf
Link attached is brochure from FR's site. Page 9 indicates that the roof is TPO.
I'd follow recommendations from others to call the dealer that you bought the unit from to inquire about the roof type.
stantyszka is offline   Reply With Quote
Old 07-07-2016, 01:55 PM   #12
Originally Posted by ilmor View Post
I don't have one, but found your manual on the Forest River app which states:
Inspection of roof components at least twice a year, is very important to make sure seams and seals are not cracked or worn. Proper maintenance of seals is necessary to keep moisture from entering and causing severe damage such as rot, mold or mildew. If you encounter dry, cracked or weathered seals, reseal or replace as necessary. Check with your dealer for the type of caulking required for rubber roofs and correct methods of resealing or replacing. A mild household soap solution and a soft brush can be used to clean a rubber roof.
Their app is actually pretty useful. I have it on both my iPhone and my iPad. used it a couple of times.
Old 07-07-2016, 01:56 PM   #13
ilmor's Avatar
It really is...and less paper to haul around in the RV!
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 07-07-2016, 02:03 PM   #14
Bingo! I burnt most of the paper manual as kindling.
maintenance, roo, roof
