Old 02-01-2011, 09:37 PM   #1
Raising her up
My 32' long WildWood trailer, when level with my Expedition, only sits several inches off the ground.
Backing it up (before the bearings went out, in another thread), can scrape the rear wheels (I have no idea what they're called), and going over uneven roads can also cause it to hit the rear wheels.
I'm tempted to take it to our local RV service place and see about having it raised up about 6". Is that advisable? Possible? Any idea what it might cost?
Thanks!
Anthony
blurngr is offline   Reply With Quote
Old 02-01-2011, 09:53 PM   #2
Now a "Top Member"
EdJunior's Avatar
Do you have a weight distribution system?
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Old 02-01-2011, 10:00 PM   #3
Yes, it's got a hitch / sway / torsion bars. Still pretty low riding. I'd say that ground clearance is only about 8" or so.
Old 02-02-2011, 02:05 AM   #4
caper's Avatar
When the trailer is on the TV are both level. Is the nose of the TT higher then the back. Can you post pictures of your setup. It would help to see what the problem is and how it could the fixed.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 02-02-2011, 07:47 AM   #5
Head Rambler
Wildwoods are not usually low sitting trailers I suspect you have a serious out of level situation. Sounds like you need a different shank length on your hitch.
Gotta go campin!
Old 02-02-2011, 08:35 AM   #6
on my last tt had the same problem wore the skid plates on tt off. put the wheels on the back helped out alot till I got the trailer on the hitch and skid wheels only then I said enough had my dealer reverse the axles fixed the problem for me. TT still rode level. TT higher hitch goes higher. Not saying make it a 4x4 but some TT need to go up.
Mike and Nancy
Wildcat 5er 2007 28rks
1999 ford f250 SD(retired)
2010 Dodge 6.7L ctd
Connecticut
mm12348 is offline   Reply With Quote
Old 02-02-2011, 08:39 AM   #7
MtnGuy's Avatar
Photos with the trailer hooked up to the Expy would be good.
Old 02-04-2011, 07:50 AM   #8
Thanks! I'll try and get pics next week. Outta town this weekend, and this snow hasn't helped anyone getting around.
Anthony
Old 02-04-2011, 08:47 AM   #9
Look under the trailer where the springs are attached to the spring hangers. Is there more holes in the hangers? If yes, then it is a simple matter of moving the springs and all other parts to the lowest set of holes. This trick alone will give you several more inches. However, now you will need to readjust all of your hitch equipment to get it hitched level with your TV.
Old 02-04-2011, 10:09 AM   #10
bsmall's Avatar
I had a similar issue with a previous trailer we owned. It kept bottoming out in the rear just by going up or down a sloping driveway. I then had the dealer flip the axles and that fixed the problem, raised the trailer up several inches....
Bill
2008 GMC Duramx-2500HD 4x4 CrewCab
52 Gallon Titan Fuel Tank
Reese18K Signature Series 5th Wheel Hitch With Slider #30085
2010 Wildcat 28RKBS (West Coast Model)
bsmall is offline   Reply With Quote
