Old 08-27-2018, 06:12 PM   #1
Bene Gesserit Rule
Murbella7's Avatar
Rear of Heritage Glen is Opening
The whole back section of my HG 28RLT is opening up at the bottom, showing sunlight through it. So far the back wall seems to be pivoting at the top and opening at the bottom, moving away from the side wall. The opening (so far) is just about half an inch. I don't know how these are attached but I would think the walls are attached to the steel frame.
Is it possible that the frame has broken allowing the wall to move? What can I do? I will post some pics when I can get out to it when the rain stops.
Murbella7 is offline   Reply With Quote
Old 08-27-2018, 06:14 PM   #2
Blender's Avatar
Yes def post pictures
Blender is offline   Reply With Quote
Old 08-27-2018, 07:55 PM   #3
Bene Gesserit Rule
Murbella7's Avatar
The Pics....
Looking forward from the rear, the right side is not quite as bad as the left side pictured here.
Name:	Rear Wall breakaway 1.jpg
ID:	184631   Click image for larger version
Name:	Rear Wall breakaway 2.jpg
ID:	184632   Click image for larger version
Name:	Rear Wall breakaway 3.jpg
Old 08-27-2018, 10:36 PM   #4
NWVIBE272's Avatar
Originally Posted by Murbella7 View Post
The Pics....
Yikes, it looks like you are getting an unwanted conversion to a toy hauler rear end.
NWVIBE272 is offline   Reply With Quote
Old 08-28-2018, 04:28 AM   #5
Ouch! That doesn’t look good.
Jfkmk is online now   Reply With Quote
Old 08-28-2018, 12:46 PM   #6
Blender's Avatar
Did you add or upgrade turbos on your TV? Geez, seems like you yanked the king pin out of the trailer with the side walls?
Just kidding, this is not a good thing?? I to have a heritage glen now Iím worried. Hopefully the manufacturer will make it worth your weight in gold!
Old 08-28-2018, 07:53 PM   #7
Bene Gesserit Rule
Murbella7's Avatar
The unit hasn't really done a lot of road work, maybe around 60,000km, but a lot of that is bouncing on non-highway roads, with potholes. I can only assume that the gussets that were supposedly welded to the frame at these main stress points have broken away.
The thought of the fixing cost is horrifying. Maybe I'll just get a long freight strap and wrap it around the rig.
Old 08-28-2018, 08:02 PM   #8
Carknocker Family
Ida Ratherbe Camping's Avatar
What it look like underneath by frame? Would be a long swim and then drive back to factory if your location is right.
Ida Ratherbe Camping is online now   Reply With Quote
Old 08-28-2018, 08:09 PM   #9
Bene Gesserit Rule
Murbella7's Avatar
I haven't crawled underneath yet. Will need to drop the underbelly skin to see anything. An yes, it would be a long swim to the factory. Knowing a little about local repair places here, it still might be worth it. Large refrigerated semi trailers repair shops are probably the best option. Quality work and experience with big boxes. I had one of those guys repair my nose cap after putting a hole in it. Great work and fantastic paint match.
Old 08-29-2018, 09:39 AM   #10
Looks like water intrusion.
2014 Ram SLT 3500 CCLB DRW Cummins
2018 Heartland Big Country 3950FB
Dan50 is offline   Reply With Quote
