Old 10-21-2017, 07:41 PM   #1
Red led on in fuse panel
Our Tipout wonít tip, electric jacks wonít work. Thereís one red led light in the fuse panel lit up. Is it lit to the corresponding fuse?
kwgirl69 is offline   Reply With Quote
Old 10-21-2017, 07:57 PM   #2
crunchman12001's Avatar
A red light indicates a blown fuse.
The jacks and slide are 12V, are you plugged into shore power or battery only?
Is your battery fully charged?
2015 F-250 FX4
Old 10-21-2017, 08:03 PM   #3
Battery is fully charged. When plugging into 110 we canít run the stuff. When we left home this morning everything was fine. There is a red light lit.
Old 10-21-2017, 08:07 PM   #4
Pull the 12V fuse that has the red light next to it and replace it. What does the panel say that fuse is for?
2015 F-250 FX4
Old 10-21-2017, 08:16 PM   #5
Old 10-21-2017, 08:17 PM   #6
Itís next to the 30. I was wrong. I thought it was the 15. We are getting a 30 to put in now.
Old 10-21-2017, 08:29 PM   #7
Flybob's Avatar
The 30A fuse is a reverse polarity protection fuse. If that blows you will have no 12V. If it blows once it is replaced, check for a battery short or a dead battery. Also check to make sure you have not accidentally pulled break-away switch.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-21-2017, 08:40 PM   #8
Thank you for your help!! It worked! New fuse has us in power again. Wonder why it blew? 2017 Wildwood. Our first trip out.
Old 10-21-2017, 09:08 PM   #9
Kbt
Our 2018 Wildwood TT has blown the 30amp fuse at least 5 times since we bought it July 3rd... we just keep lots of extras on hand.
Kbt is offline   Reply With Quote
Old 10-21-2017, 09:30 PM   #10
SailorSam20500's Avatar
5 times in 3 months??? You have a problem and you need to find out why the fuse is blowing. That's a safety issue!!!
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
fuse, led
