Old 09-02-2019, 12:17 PM   #1
Refrigerator Cooling on Truck Power
Will my refrigerator cool while on truck power and traveling? We donít want to use propane. Thanks!!!
plh869 is offline   Reply With Quote
Old 09-02-2019, 12:24 PM   #2
NMWildcat's Avatar
If it's a two way fridge, then no, it will only work on propane or 110v.
If it's a residential fridge, also no, it only works on 110v.
If it's a three way fridge, then yes, it will work on 110, 12v, or propane. These are usually in aframes and pop-up type RVs.
Scott and Liz - Southern NM
Old 09-02-2019, 01:25 PM   #3
Step number 1 is to make sure that your truck is supplying power to your trailer. Many vehicles need a fuse and/or relay installed to accomplish this through the 7 pin connector.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 09-02-2019, 01:50 PM   #4
rsdata's Avatar
My Dometic fridge keeps things cool for at least two days without being turned on IF I fill the freezer with frozen water bottles, and pre-cooled items in the fridge part. It is actually a really good "cooler" once cold and filled with already cold items.
ďToo much of anything is bad, but too much good whiskey is barely enough.Ē Ė Mark Twain
2014 Shamrock 183
Old 09-02-2019, 02:01 PM   #5
bikendan's Avatar
Since you have no info on your RV, listed in your profile and you didn't post make and model of fridge, there's no way to give you much help.
Is your fridge a 2-way fridge or 3-way fridge or residential fridge?
Equalizer WDH
cooling, power, refrigerator, truck
