Old 09-11-2019, 07:46 PM   #1
Replacing LED awning lights that attach under awning bracket
We have a 2016 Wildwood Xlite 171RBXL whose LED lights have quit working.
We do not have any other outside light so I would like to replace them. The trouble is, the light strip goes under the awning bracket. I will have to loosen the awning bracket in order to make the change. The bracket is sealed with black sealer. Very poor design. Forest River has been no help. Has anyone loosened their awning bracket in order to change these lights out with better waterproof lights?
tdjackson is offline   Reply With Quote
Old 09-14-2019, 08:41 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. I have not removed the lights but have removed the awning brackets. After cleaning the area I used a color of silicone sealant that matched the bracket color when reattaching. Youtube has a bunch of videos on replacing awning lights.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 09-14-2019, 01:18 PM   #3
Thank you SeaDog for the info. My concern was the fact that the lights go behind the bracket. I thought I might be able to take them off without loosening the bracket. It looks to me that I will have to loosen it enough to to get the end out and connection undone. I'm also concerned that I get lights with the same connection.
The service dept where I purchased the RV has Carefree Awning lights that are supposedly waterproof and warranted for three years. Cost $160. They want an additional $120 to do a full install. Forest River is no help at all.
Name:	Stack-On - 4.jpg
ID:	214944   Click image for larger version
Name:	Stack-On - 1.jpg
ID:	214945   Click image for larger version
Name:	Stack-On - 2.jpg
ID:	214946   Click image for larger version
Name:	Stack-On - 3.jpg
Old 09-14-2019, 01:50 PM   #4
dannyabear's Avatar
The bracket covers the hole in the outside wall that the wires come thru; why spend so much for them, buy on ebay or amazon for about $15
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 09-14-2019, 01:56 PM   #5
cboss's Avatar
Check out these lights. I've used them for years.
https://www.boogeylights.com/led-lig...EaAqzhEALw_wcB
Craig & Cath
2018 2902WS Rockwood Ultra Lite
2017 Ford F250 Lariat, 6.2 gas
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2016(retirement): 740
cboss is offline   Reply With Quote
Old 09-14-2019, 07:28 PM   #6
Thanks Dannyabear and cboss.
I want to make sure that the connector ends match on anything I replace the lights with. I presume that I could just splice the ends together. I would like to have genuine waterproof lights. Our RV stays outside with a fabric cover.
I really didnít want to take the bracket down but it seems I will have to loosen it at least. Most of the lights that I saw on an RV lot the connections were outside the bracket. Piece of cake then. Poor job FR.
awning, led, light
