Old 03-04-2015, 11:00 PM   #21
Mrs Evans's Avatar
Originally Posted by dannyabear View Post
The Kumho 205r14 is about 1 1/2" larger in diameter and would be too close in my aplication. I was going to buy the Kumho in 195r14 but was told that size was discontinued. I bought the Hankooks RA08 in size 195r14 from the busdepot.com
$508.00 for 4 shipped to my house, and had mounted and balanced at local tire shop, sold the 1 year old Westlakes to a local grass cutter for his utily trailer.
It is also important to ask the date of mfg. on the tire before buying, the busdepot had the best price and tires were mfgd only 4 months earlier.
Goodness, trying to figure out this tire stuff is challenging! I'm glad and very much appreciate all the help offered on this forum!
Michelle Evans
Katy, TX
2011 Carriage Cabo 341
2014 Wildwood 231RBXL - Traded Her In
2016 Days Camped = 5; Reserved = 14 so far
2015 Days Camped = 24 / 2014 Days Camped = 23
Mrs Evans is offline   Reply With Quote
Old 03-04-2015, 11:26 PM   #22
TexasToast (HOT Summers)
chinese tires
Hello Mrs. Kumbo!
i must ask if your tires are made in China?
normally the tires that Forest river installes on the campers are of Chinese origin. i can tell you that our 5th wheel camper had only about 1200 miles on it when the first tire "blew" out on us. of course i had a spare ("chinese') tire that i used to change the blown out one. it was very nice to have that option except for the Damage that was incurred on the camper. ( it caused damage to the underneth of the camper and also the floor of the living area. about 200 miles later i lost another tire which (thank God only damaged a little bit of the fender.) I replaced ALL tire as soon as i got to a discount tire company and found the BEST tire available.
i purchased the MAXXIS (m8008 trailer tires) that were in stock that "according" to a search engine and Tire brands was supposed to be the best for Campers.
So far we have approx. 9,000 miles on the tires with NO issues.
this cost me $500.00 for my deductible to repair the camper and of course it is never in factory condition ever again.
Chinese Bomb tires will really tear up your camper.
No matter how much you use your camper it is recommended that you change the tires every 5 years..
best of luck
dalestow is offline   Reply With Quote
Old 03-04-2015, 11:53 PM   #23
Mrs Evans's Avatar
I just did a search for the Kumho 195 vs 205 and it's surprising just how much more expensive the 195 is, nearly the double the price! Yikes!
Michelle Evans
Katy, TX
Old 03-05-2015, 12:06 AM   #24
dannyabear's Avatar
The Hankook RA08 size 195r14 is $109.00 each at busdepot.com
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 03-05-2015, 12:13 AM   #25
Mrs Evans's Avatar
That's more in line with the budget, I'll check it out
Michelle Evans
Katy, TX
Old 03-05-2015, 12:33 AM   #26
GreenImp's Avatar
Send a message via MSN to GreenImp
Originally Posted by MartySantic View Post
Will be replacing the C range tires with D range tires and my short list looks like this, in order of preference.
Maxxis M8008's
Kumho 857's
Goodyear Marathons
Will be adding the TST Flow Thru TPMS on the 4 trailer tires and the 4 truck tires.
Hope this helps you. AND I welcome any comments on my list.
Deal Alert...
Discount Tire Direct, already one of if not the cheapest place for these tires, currently has a $100 off of a $400 or more purchase done through eBay/Paypal. They don't offer the Kuhmo's, but both the Maxxis and Marathon's are available in various sizes.
I just recently purchased 225 75 15 D Marathons through them and the tires I received were only a few months old.
I also just purchased the TST 507, and the best price I found was through InfoTech RV Solutions @ $220 shipped (4 sensors). The kit was "drop shipped" straight from TST. My kit was missing a small part, and both InfoTech and TST were all over getting it taken care of FAST.
Motor home TPMS SYSTEMS PRESSURE TRACK TIRE PRESSURE MONITORING SYSTEM,TPMS, RV TIRE MONITOR, RV TPMS SYSTEM
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2021 Solitude 310GK w/FBP
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 03-05-2015, 05:35 PM   #27
jawga's Avatar
but u can get the hankooks through discount tire, thats where we got ours from
jawga is offline   Reply With Quote
Old 03-05-2015, 06:45 PM   #28
Mrs Evans's Avatar
Yep, it looks like you can order through them. Thanks for the suggestion
Your trailer probably has the same tires as ours, did you get the 195R14 tires?
Michelle Evans
Katy, TX
Old 03-05-2015, 08:20 PM   #29
jawga's Avatar
yup 195R14 fit perfectly does not sway as much either
Old 03-05-2015, 08:26 PM   #30
dannyabear's Avatar
Me too!!
Danny & Darlene
Old 03-05-2015, 08:32 PM   #31
Mrs Evans's Avatar
Me too!!
Cool! With you and @jawga having the same year and similar sized trailers, it sounds like the Hankook 195R14 tires will be the way to go - along with getting a TPMS
Did either of you have to get new rims?
Michelle Evans
Katy, TX
Old 03-05-2015, 08:48 PM   #32
As I have stated several times, I wouldn't pull a camper off the dealer's lot with the LR C factory tires. They may be load rated more than the axles, but the axles will slowly bend if overloaded or mistreated with minor damage to anything but the tires, excluding burnt brgs, etc. whereas a tire blowing will cause major instantaneous damage.
Old 03-05-2015, 08:48 PM   #33
jawga's Avatar
Researching Tire Options for Wildwood 231
yup the rims i got are rated for over 2000lbs also to handle the higher pressure u need the metal valve stems, when i had discount install them they put in the metal valve stem, i also bought the certificate for replacement tires since it was so cheap, take a look at some of my other posts, i show pics of my new tires and rims and also what type of rims and where i got them from, the rims were around $75 each, overall very happy
Old 03-05-2015, 08:53 PM   #34
dannyabear's Avatar
I kept and used my original mag style alloy wheels that came with the 'Emerald package"
Danny & Darlene
Old 03-05-2015, 09:05 PM   #35
jawga's Avatar
guess i should have stated my camper originally came with the standard white spoke steel wheel, nothing fancy
Old 03-05-2015, 09:46 PM   #36
Mrs Evans's Avatar
I hear you, it's not so much whether we get new tires but what kind specific to our rv trailer. The forums contain so much info and sorting through it can be overwhelming but we pretty much figured that new tires are in order
Michelle Evans
Katy, TX
Old 03-05-2015, 09:48 PM   #37
Mrs Evans's Avatar
Yep, we currently have the standard white wheel and I figured we'd probably need new rims as well as metal valves
Michelle Evans
Katy, TX
Old 03-05-2015, 10:47 PM   #38
I personally like and have used Goodyear Marathons for over 40 years with not one problem. If LR D are available in your size, that's what I would buy.
tire, wildwood
