Old 03-05-2015, 07:32 PM   #31
Mrs Evans's Avatar
Originally Posted by dannyabear View Post
Me too!!
Cool! With you and @jawga having the same year and similar sized trailers, it sounds like the Hankook 195R14 tires will be the way to go - along with getting a TPMS
Did either of you have to get new rims?
Michelle Evans
Katy, TX
2011 Carriage Cabo 341
2014 Wildwood 231RBXL - Traded Her In
2016 Days Camped = 5; Reserved = 14 so far
2015 Days Camped = 24 / 2014 Days Camped = 23
Mrs Evans is offline   Reply With Quote
Old 03-05-2015, 07:48 PM   #32
As I have stated several times, I wouldn't pull a camper off the dealer's lot with the LR C factory tires. They may be load rated more than the axles, but the axles will slowly bend if overloaded or mistreated with minor damage to anything but the tires, excluding burnt brgs, etc. whereas a tire blowing will cause major instantaneous damage.
Old 03-05-2015, 07:48 PM   #33
jawga's Avatar
Researching Tire Options for Wildwood 231
yup the rims i got are rated for over 2000lbs also to handle the higher pressure u need the metal valve stems, when i had discount install them they put in the metal valve stem, i also bought the certificate for replacement tires since it was so cheap, take a look at some of my other posts, i show pics of my new tires and rims and also what type of rims and where i got them from, the rims were around $75 each, overall very happy
jawga is offline   Reply With Quote
Old 03-05-2015, 07:53 PM   #34
dannyabear's Avatar
I kept and used my original mag style alloy wheels that came with the 'Emerald package"
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 03-05-2015, 08:05 PM   #35
jawga's Avatar
guess i should have stated my camper originally came with the standard white spoke steel wheel, nothing fancy
Old 03-05-2015, 08:46 PM   #36
Mrs Evans's Avatar
I hear you, it's not so much whether we get new tires but what kind specific to our rv trailer. The forums contain so much info and sorting through it can be overwhelming but we pretty much figured that new tires are in order
Michelle Evans
Katy, TX
Old 03-05-2015, 08:48 PM   #37
Mrs Evans's Avatar
Yep, we currently have the standard white wheel and I figured we'd probably need new rims as well as metal valves
Michelle Evans
Katy, TX
Old 03-05-2015, 09:47 PM   #38
I personally like and have used Goodyear Marathons for over 40 years with not one problem. If LR D are available in your size, that's what I would buy.
tire, wildwood
