Old 02-12-2012, 03:58 PM   #1
Rim Pressure
Ok Guy's here goes! If you go from a C rated Tire to a D rated tire
how do you determine if the Rims will hold the extra pressure/
225-75R-15-C
225-75R-15-D Thanks
Norm
2005- WDF27RLSS
2001-Dodge-4/4- souped up Cummins
1953 Willys 4/4
1970 Restored Cushman Trackster
Olratlr is offline   Reply With Quote
Old 02-12-2012, 04:26 PM   #2
Check your rim and see if it is stamped on them. It should be along with the rim size. From what I understand the bolt in style valve stems are rated a little higher as well.
rkswyo is offline   Reply With Quote
Old 02-12-2012, 06:55 PM   #3
Most "D" rated tires are only going to require 60 psi or so, so rims will be fine. It's when you go over 80 psi you need to start thinking about rim pressure ratings, and high pressure valve stems.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 02-12-2012, 07:18 PM   #4
I agree, I wouldn't be worried about it. If it is a 5 lug wheel the wheel will be the limiting factor load wise. A 6 lug or 8 lug wheel will have a higher load capacity.
Old 02-13-2012, 07:49 AM   #5
Thanks to all of you Guy's for the expertise.
2005- WDF27RLSS
1953 Willys 4/4
