Old 08-14-2018, 03:59 PM   #1
roof issue
While cleaning the roof of my Camper yesterday I found a place where something sharp was sticking up it hadn't full pentatraded the membrane yet but I could fill the sharp point.
Forest river said to contact the dealer first, after talking with them it doesn't seam that they will get approval to look at it as it is out of the one year warranty.
If this gets turned down who can I contact at forest river to get this issue straightened out.
I have already covered the area with eturna bond.
2016 wildwood x-lite 241qbxl
being jurked down the road by the beast 2007 Dodge ram 2500
5.9 cummins g56 Trans southbend clutch and a smarty
railroaderone is offline   Reply With Quote
Old 08-14-2018, 04:17 PM   #2
rsdata's Avatar
since it has not penetrated I doubt anyone will do anything under a warranty... you did the right thing to put eternabond on it... keep an eye on it
Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
rsdata is online now   Reply With Quote
Old 08-14-2018, 04:21 PM   #3
Coach
Roof work isn't quite the monster on these things that it's made out to be. Your best bet is probably to try and Identify what is sticking up. (Screw, piece of flashing, etc.) Once you know what your dealing with you can probably figure out a way to fix/remove. It doesn't sound like something that would likely be covered by warranty unless it's due to negligent craftmanship.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 08-14-2018, 05:36 PM   #4
that's what I'm claiming it is. There is no way anything should work it's way up though the membrane
roof, wildwood
