sanitization of fresh water
I have a question on sanitization
i have a new camper and i aslo have an older camper.
is it wise to fill water tank and sanitize before use and do you disconnect the city water to the water incoming connection and let the fresh water pump push the chlorinated water through the system, can you push a backflow valve to let it come out the incoming water hose connection
or if you dont normally use the fresh water tank, and only use fresh city water connection from hookup, do you have to sanitze the system
thanks
