09-06-2010, 03:28 PM
Satellite TV
Hi folks....I'm new to Direct TV. Love it at home and the installer was nice enough to give me a dish for the trailer too. Unfortunately I'm having a hell of a time getting a signal even when I have a direct view of the southern sky. I have the dish on a tripod, it is level and I even tried using a signal finder. Still no luck. Now, I have been attaching the coax to the outside cable connector instead of going directly to the receiver. Is there some alternate wiring through the antenna that is tripping me up or do you know of something else that I could perhaps be doing wrong.....or.....is pointing the satellite really just that hard and I should drop the $700-800 on an automatic satellite finder? Thanks for any tips you may have.
09-06-2010, 03:50 PM
It is not easy to find your satellite, and even a satellite finder doesn't help that much as it finds ALL of them!
What I do is get a compass bearing at home, and as long as I am not going to far, that is my starting point. The I just move the dish in increasingly larger circles until I get a picture. Sometines I get it right away, sometimes takes a while.
If you are going any distance from home, you will need to get the compass bearing plus the angle up from the horizon (azimuth?) from your provider.
But those fancy, and expensive, rv dishes do look appealing!
09-06-2010, 03:52 PM
Directv
First off, you need to try running the cable straight through a window to the receiver. There is a setup program in the receiver that you can access with your remote. Put in the zip code where you are located, it will give you the azimuth, ele & tilt. You will need a compass for the SW heading, will not be able to get a signal under trees and the post the dish is mounted on is perfect vertical.
In the receiver set up, there is also a meter with a BEEPING sound, turn up the volume on TV, open window or door so you can hear the beep when it increases as you get on the signal, you can watch your meter near the dish to fine tune the signal. Takes practice but it will work. The receiver sends down the cable to the dish approximately 9-18 VDC to power the LNB on the dish. this is the reason I said to run it through a window or door. Once you get the signal, try hooking it to the connection on the side of your camper to see if it will work.
Sid & HRH- Daisy the Boykin.
2011 ROCKWOOD 8285 WS
2005 F-150 SUPERCREW
SUPER GLIDE HITCH
09-06-2010, 04:21 PM
Jan Goldfield
Did the nice Direct TV man leave you a receiver for your RV? If he didn't, take the one from the house and install it in the RV when you are traveling. Put it back in the house when you come home.
Jan Goldfield and Donna Morse
Slidell LA
2009 Cherokee Grey Wolf 28BH
2009 Ford 150
http://www.pondlady.com
09-06-2010, 04:24 PM
Pond lady got tent pegs?
Pond Lady, did you find the tent pegs for your dish tri-pod?
SUPER GLIDE HITCH
09-06-2010, 04:26 PM
Jan Goldfield
Not yet. And I was in the sporting goods store today. I did not have my list with me and I have a mind like a sieve. The tripod/satellite is not here yet. When it arrives, I will make another trip.
Slidell LA
2009 Ford 150
09-06-2010, 04:27 PM
Thanks for the tips...I was bright enough to bring the receiver from home though not all that much brighter...I guess I'll keep practicing. I really don't want to drop that kind of money for the auto finder.
09-06-2010, 04:38 PM
Takes practice!!!!
Takes practice, that is all. Once you get "IT" the first time (signal that is) and fine tune it. It is pretty much like a scope on a rifle, the view to the SAT is pretty narrow. Also, you will get your local channels up to about 200
miles. After that no more local channels, all others no problem!
SUPER GLIDE HITCH
09-06-2010, 05:07 PM
You may have an issue like I had with our new trailer, I tried hooking up my Expressvu system and could not get anything either and noticed as well that I was getting a high pitched nois coming from the booster at the same time when I had the receiver plugged in. Even with the booster off there is power that is supplied to the cable that goes outside in case you wish to use a tv outside so you will get the boosted signal from the antenna. My RV dealer told me I would have to take the plate off the ceiling and disconnect the cable from the back side that goes to the outdoor outlet and connect it through a separate pass through connector to isolate it from the booster. This probably would have worked for me but it looks like I may have a cable in my trailer coming from the outside that has a nail or staple through it as it still never worked for me. I eventually ran a new cable through and connected it to the outside outlet.
Hope this helps you out, the quickest way to tell though would be as mentioned above to run a cable right through a window direct to the receiver until you get the dish lined up, then try it through the other outlet, if the signal disappears then you will know that you have the same issue as I did.
09-06-2010, 06:24 PM
The problem is most likely with the antenna amplifier. If you are connecting the coax cable from the sat receiver directly to the connector on the amp and then connecting the dish to the outside connector things will not work as expected. The sat receiver puts out a DC voltage to the amplifier on the dish itself (the LNB). The antenna amp plate contains electronics that will block that voltage so the dish won't work.
I put a new plate in that as 2 coax connectors on it. The backside of one connector (call it #1) goes to the outside connector (moved cable from the back of the antenna amp) the backside of the other connector (call it #2) goes to the now vacant connector on the back of the antenna amp.
When I use the satellite I connect the receiver satellite connection directly to connector #1 and connect the AV output to the TV. If I should ever be some where that has cable on site then I would connect a short coax between #1 and #2.
I still have the output of the antenna plate connected to the coax input of the TV so I can switch between satellite and antenna.
I can try and draw picture if necessary.
Joel
Joel K
Southeast AZ
2010 Wildwood T28RLSS
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 539 |
| 112 members and 427 guests |
| 09grizzly1, 10Isola, 2000XLifted, 2Bushes, Acableguy06, Adony, AvalancheR-pod, bfast54, bikendan, Bob Norquay, booneandbuck, Borwick, bsmall, Camping Dad, caper, cardimom, Cccross3, cebaker, cmleach, coverup, cowpaddy, Dave_Monica, dc31bhss, dckoski, DDC, DF5.4, donh, donn, DougP47, Drmstx62, Earth Station, Ed D, EdJunior, Ex5ver, F and E Damp, Falcon35, flc, flyrotor, Forbes, GASPEDDLER, GD13, HemiCab, herk7769, Hob, HondoPatrick, JFM-jr, JKGreene, jodyand, JoeR, JohnT, Kamper, katsmeow62, Kbrazieltx, kz08h5, lavigne, Lawfive, lefaivre, Linnemj, longarrow, lowbubba, LunaTech, Malco, Mark1978, mgcmn, michel, Michigan-traveler, mike7431, miked11272, mstell2, mtworks, Newellri, Oakman, overthehillbill, padave65, papap, phrogdriver93, Pinesman, Pitcrew18, polkatronron, puckdad, radurecka, Rambler, RANGERBOB, rbq, realebill, RoadDog66, rparker, rschoono289, SabreMarv, shooted, Slow_movin, smithmdsmith, Sooner Travelers, Steve7575, Swinks, TaterColo, Tbeasley77, tbritt, tcoop48, teamgl, tentcamper1, Terier, tking01_2000, tking1866, tomwhite, transamz9, TTNewbees, van_fl, vcarbona, wildcat2k6, Wisconsin Camper, youroo |
| Most users ever online was 881, 06-22-2011 at 11:07 AM. |
