Old 04-30-2017, 11:00 AM   #1
phillip252's Avatar
Screw trim cover cracked
Has any one had any issue with the screw trim on the front two corners cracking? This is on a wildwood x lite 261BH. I will post pic later today.
phillip252 is offline   Reply With Quote
Old 04-30-2017, 11:05 AM   #2
Buy a 100' roll,you will need it,that Insert gets Brittle/Hard! Youroo!!
Old 04-30-2017, 11:07 AM   #3
phillip252's Avatar
Old 04-30-2017, 11:19 AM   #4
crunchman12001's Avatar
X2, Here is a tip. Pull any screw that looks a little rusted, fill the hole with sealant and reinsert a new screw. Install new vinyl screw cover. Also, place the roll in sun to make it more pliable.
2015 F-250 FX4
Old 04-30-2017, 12:28 PM   #5
PoPo Cliff's Avatar
What can be done to help prevent this? Is there a treatment that can be used?
2017 Flagstaff 26RLWS
PoPo Cliff is offline   Reply With Quote
Old 04-30-2017, 12:58 PM   #6
screw cover
Look carefully at the trim before you buy, some is made in China and is very thin. It will dry and crack very quickly. I will just keep the roll around and replace the trim as it dries out. As it is not really rubber, I don't know that there is anything you can treat it with to protect it.
tom2t is offline   Reply With Quote
Old 04-30-2017, 01:36 PM   #7
PoPo Cliff's Avatar
Old 04-30-2017, 07:07 PM   #8
phillip252's Avatar
I was thinking the same thing , pop cliff.
Old 04-30-2017, 08:10 PM   #9
SARDogDad's Avatar
Where to buy?
Where can you get this trim?
SARDogDad is offline   Reply With Quote
Old 04-30-2017, 08:36 PM   #10
the link below is what I used, ... do remember, it does shrink some in a short time, so allow for that .............
https://www.walmart.com/ip/Camco-Vin...Black/29764302
fella10 is offline   Reply With Quote
cover, crack
