04-30-2017, 11:00 AM
Screw trim cover cracked
Has any one had any issue with the screw trim on the front two corners cracking? This is on a wildwood x lite 261BH. I will post pic later today.
04-30-2017, 11:05 AM
Buy a 100' roll,you will need it,that Insert gets Brittle/Hard! Youroo!!
04-30-2017, 11:07 AM
04-30-2017, 11:19 AM
X2, Here is a tip. Pull any screw that looks a little rusted, fill the hole with sealant and reinsert a new screw. Install new vinyl screw cover. Also, place the roll in sun to make it more pliable.
2015 F-250 FX4
04-30-2017, 12:28 PM
What can be done to help prevent this? Is there a treatment that can be used?
2017 Flagstaff 26RLWS
04-30-2017, 12:58 PM
screw cover
Look carefully at the trim before you buy, some is made in China and is very thin. It will dry and crack very quickly. I will just keep the roll around and replace the trim as it dries out. As it is not really rubber, I don't know that there is anything you can treat it with to protect it.
04-30-2017, 01:36 PM
04-30-2017, 07:07 PM
I was thinking the same thing , pop cliff.
04-30-2017, 08:10 PM
Where to buy?
Where can you get this trim?
04-30-2017, 08:36 PM
the link below is what I used, ... do remember, it does shrink some in a short time, so allow for that .............
https://www.walmart.com/ip/Camco-Vin...Black/29764302
05-01-2017, 11:43 AM
you can order it on Amazon too... check the color and width before ordering.
07-10-2017, 12:51 PM
My 2017 282XBXL did the same thing pulling it back from a long July 4th trip.
I wounding if they got a bad batch? My 2017 282QBXL did the same thing last weekend. I have not even had a year yet. Is it even worth trying to do warranty on it? Is there one brand that is better than the other for UV?
07-10-2017, 03:48 PM
The black is usually a little better at standing up to UV better than white, but it gains more heat so it's probably a wash.
You can spray a little 303 protectant on it and that will add some UV protection to it.
Gotta go campin!
07-14-2017, 11:46 AM
how close are you to the dealer? If its a short drive, I'd let them replace it (push them to replace it all)
If its a long drive, its cheap enough you can just do it yourself.
