Old 04-28-2016, 10:39 AM   #31
leefl's Avatar
Originally Posted by Wolverine 1945 View Post
Not sure I know how to add a link,,, There are several videos on Ytube,,,
The one I have been speaking of is a Lippert video,,,
In Wall Slid-Out System - Mechanism Lubrication...
I think that's the one I've seen, and is for the smaller slideouts, like the closet slideout they show, using the Schwintek system that has an in-wall motor attached to each slide rail ; rather than the type that has a single motor above the slideout and a cable system for closet slide-outs like mine, or the bigger system for room-slides.
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
leefl is offline   Reply With Quote
Old 04-28-2016, 10:59 AM   #32
Originally Posted by leefl View Post
If we saw the same video then it was for the Schwintek slide system, which has motors on each side of the slide, and is most commonly used for smaller slides (like closet slides) and is very different from the system on the bigger & more traditional slides, like our sofa/dinette slide, which have rails that go under the main floor.
If there's a different video, then I'd appreciate a link
Very correct statement that most fail to realize.
The Schwintek is an in wall slide system. (closet/wardrobe slides)
Two motors drive two rails attached to the slide side walls.
Then there is the through frame slide system. (dinette/sofa slides)
Two rails under the slide go through the frame and driven by a rack system.
And finally the above floor slide system. (bed slides)
Similar to the through frame but completely enclosed inside the trailer. (usually under the bed)
All completely different.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 44
slide, slide out
