Old 04-25-2016, 01:53 PM   #1
jgump's Avatar
Slide out Squeaking bad
On my wildwood 27rkss when I put the slide in, it makes a terrible squeaking sound for almost the whole time it's moving in. I've sprayed the rack and pinion underneath with slide out dry lube but maybe there's something else causing it. Any ideas? Maybe just more dry lube? It's definitely not emanating from the rubber seals around the edge so must be something underneath. Thanks all!
John
2016 Wildwood 27RKSS
2012 Grand Cherokee Overland (Hemi)
jgump is offline   Reply With Quote
Old 04-26-2016, 10:12 AM   #2
Head Rambler
Did you spray the tracks that extend under the RV as well? That's probably where the noise is coming from if you didn't.
Gotta go campin!
Old 04-26-2016, 10:53 AM   #3
jgump's Avatar
Good Call Bama - I sprayed the pinion and the rack that slides out with the slide, but didn't crawl under the rig to also spray that rack down. Will be giving it a dose of dry lube next time I get it ready to camp during Mem Day and will report back. Happy Camping!
Old 04-26-2016, 11:05 AM   #4
B and B's Avatar
Also check the slide blocks inside. On my Rockwood they replaced them at Goshen because of squeaking then a year later they removed them entirely saying they were not required. I would check to see if your has these and also with the division to see if they are even required.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 04-27-2016, 07:31 AM   #5
jgump's Avatar
Thanks B&B - these blocks, are they they plastic on each corner of the inboard edge? Maybe a little lube on them too? Weird thing is that this squeak started after say moving the slide in/out - dozen times or so. Prior to that it was quiet. I'm hoping it's a lube issue.
John
Old 04-27-2016, 07:41 AM   #6
Wolverine 1945's Avatar
If you Google the Slide Manufactory,,, you will find videos of how to lub slides !!!
Wolverine 1945 is offline   Reply With Quote
Old 04-27-2016, 07:49 AM   #7
jgump's Avatar
Great! I'll check it out.
John
2016 Nights Camping "4"
Old 04-27-2016, 08:16 AM   #8
Apply "Aerospace 303" on all the Seals there are "Inside & Outside" seals be sure to Coat BOTH Sides of ALL Seals! Youroo!!
Old 04-27-2016, 09:17 AM   #9
leefl's Avatar
I too have a squeak that starts and stops when moving our large slide in/out, and the noise is definitely coming from under the main floor, so I'm guessing it's the tracks.
I haven't had a chance to look yet, but I'm betting they're covered by the underbelly skin
Maybe I can just apply some dry lube to rails when extended, and it might help.
Do folks recommend using silicone lube or dry lube ?
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
leefl is offline   Reply With Quote
Old 04-27-2016, 09:24 AM   #10
Head Rambler
For sliding components it's best to use dry lube as it won't accumulate dirt and dust like wet lubes will.
Gotta go campin!
slide, slide out
