Old 08-29-2016, 05:24 PM   #11
Did that already. Thanks!!
Denise13065 is offline   Reply With Quote
Old 08-29-2016, 05:25 PM   #12
Thank you, been there and done that twice.
Old 08-29-2016, 05:27 PM   #13
I will give that a try, Thanks. I'm the only one with a Washer and my neighbor's camper (also a Sierra) is way worse than mine, so it makes me think there is a flaw in the water lines somewhere. The camper on my other side, no issues whatsoever.
Old 08-29-2016, 05:56 PM   #14
Witch Doctor's Avatar
You might try a pure external carbon filter, also west marine sells a product that is called sweet water. put that in your holding tank. I don't think that the plumbing lines are the problem. Maybe I missed this but are you at a seasonal spot. Water will turn nasty if it just sits in your lines for a couple of weeks. If you on a well the smell could be worst, if that is the case open your low point drains before you leave and then close them when you return,
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
water
