Old 09-14-2016, 03:48 PM   #1
Question stabilizer jacks 262BHXL -
Hello,
Front are down back won't go down....can't get remote to work(works for awning and slide out).
Where is fuse at ?
thanks,
7ofusinGA
SevenOfUsInGA is offline   Reply With Quote
Old 09-22-2016, 12:25 PM   #2
my fuse was under the refridge. remove 2 screws to get to the panel.
(this is not the main fuse panel)
there is also an inline fuse by the motor, but it should reset automatically I think.
I had trouble with my rear jack and ended up wiggling the wires at the motor and it started working... so try that too.
mkosu04 is offline   Reply With Quote
Old 09-23-2016, 07:26 AM   #3
I have a 261bhxl. One time when my front Jacks wouldn't work, I discovered that the wires had come completely off the inline fuse. I guess the nuts vibrated off the terminal screws. These fuses are located on the curb side right above the motors. Follow the wires.
2016 Salem Cruise Lite 261bhxl
Ram 1500 5.7l Hemi Crew Cab 4wd
gspot01 is offline   Reply With Quote
jacks
