Old 07-22-2014, 09:45 PM   #1
Suburban oven burns
Hello all, we just bought our wildwood tt and we can't seem to use the oven without burning everything. Ideas please? Thanks in advance.
Hapy.Trainer is offline   Reply With Quote
Old 07-22-2014, 09:47 PM   #2
NELA
Weezer's Avatar
Have you tried a pizza stone? It evens out the heat.
Do a search here on the forum about it.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 07-22-2014, 09:51 PM   #3
Herk7769's Avatar
Ditto on the Pizza stone. I have no idea how you use these ovens without one to even out the heat.
Search "pizza stone" for links and stuff.
HAM CALLSIGN - KC3FFW
Old 07-23-2014, 04:24 AM   #4
rburns4147's Avatar
Unglazed tile also works. I have 16 in my oven...Had to trim the sides of four to get them to fit (I have a tile saw). It is the same principle as a pizza stone and found them at Home Depot. Most tiles are glazed so you have to look for the unglazed ones.
Ron and Elizabeth
2014 Rockwood 8285-IKWS
2006 Ford F250 6.0 Diesel 4x4
rburns4147 is offline   Reply With Quote
Old 07-23-2014, 04:49 AM   #5
DAISY BOYKIN's Avatar
Oven that burns---------------
We too had the same problem with the oven burning everything on the bottom. Tried the pizza stone trick, still burned. Then DW was watching the cooking channel about a oven burning things on the bottom, the simple fix was to wrap the bottom of your pan or container, muffin pan, pie pan with aluminum foil. Use a piece of foil to cover the bottom completely and up over the edge of the pan to secure it in place.
This simple trick prevents the bottom of what ever you are baking from burning.
First time I tried it, could not believe it worked.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 07-23-2014, 06:48 AM   #6
In our previous camper we had a tile in it and still things burned. I bought an oven thermometer and discovered the oven thermostat was not working. I returned it to the dealer, they replaced it under warranty and all was good.
comfun1 is offline   Reply With Quote
Old 07-23-2014, 06:54 AM   #7
We had the same issue purchased a pizza stone from bed bath and beyond for around $20. worked great wife made cinnimon rolls and biscuits without any issue.
2013 Ram 1500 (5.7)
2014 Rockwood Mini Lite 2104s
http://i307.photobucket.com/albums/n...ps412bc14c.jpg
Prothos is offline   Reply With Quote
Old 07-23-2014, 07:10 AM   #8
Hi,
When we first tried the oven on our Silverback, it put out 450 degrees no matter where the dial was set.
Between a new thermostat (under warranty) and four 6" unglazed tile ($.89 each at Menards) it's spot on now.
FWIW.
Rich Phillips
richp is offline   Reply With Quote
suburban
