Old 04-26-2017, 10:33 PM   #1
Suburban water heater won't ignite
Any Ideas? Turn the switch on. Igniter wont click. Fault light illuminates. Gas valve is working. I manually light it. It initially lights for a few seconds and then shuts off. We have been using this heater for less than 10 days "camping" this is a 2017 model we just bought.
ronj82 is offline   Reply With Quote
Old 04-26-2017, 10:36 PM   #2
gpaw56's Avatar
Might have to let air bleed out. Give it a couple of opportunities
gpaw56 is offline   Reply With Quote
Old 04-26-2017, 10:37 PM   #3
SeaDog's Avatar
sounds like you have a faulty ignitor which is also part of your flame proving circuit, thus the unit lights with a match and goes out right away because there is no flame sensing. I'm not familiar with a fault light could you explain
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 04-26-2017, 10:52 PM   #4
We have been using the heater since sunday so shoudl be bled out fine. I can smell propane when the valve actuates just no igniter.
Old 04-26-2017, 10:54 PM   #5
So the igniter itself could be bad? Im away from home. Dont have my multimeter with me to check continuity. So manually lighting it wont work with a bad igniter?
Old 04-26-2017, 10:57 PM   #6
The fault light above the switch comes on if it fails to light.
Old 04-27-2017, 01:54 AM   #7
Any chance you are nearly out of propane?
samwlee is offline   Reply With Quote
Old 04-27-2017, 01:55 AM   #8
If possible take it back to dealer and get warranty to fix it
Old 04-27-2017, 02:52 AM   #9
Witch Doctor's Avatar
If his is like mine SeaDog, it's a small red led on the switch when you turn it on the red light shows you that it is igniting, once it lites off the red led go's off. Then your rocker switch just is blue showing you its on....
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-27-2017, 03:34 AM   #10
Why not go through all the detailed troubleshooting steps in the Suburban install manual?
Mr Havercamp is offline   Reply With Quote
heater, suburban, water, water heater
