Old 12-05-2015, 09:23 AM   #1
Rivet's Avatar
Television Mount
I noticed after our first outing that the TV mount I installed was coming out of the wall. When I ordered it from Amazon it didn't show up in time for the dealer to install it, so I did it myself. Using the sticker on the wall as a guide, I used my best guess and I thought the screws were hitting solid wood. After the install of the backer plate, the wall protruded outward about a quarter inch.
Long story short, the screws were coming out when we got to our first stop (about 8 hrs driving). The TV is a lightweight 24" dealio. Am I missing the studs in the wall, or whatever they put in there? When I retightened the wood screws they seem to go back into solid wood and the wall is no longer protruding. Click image for larger version
Name:	ImageUploadedByForest River Forums1449329008.876823.jpg
Rivet is offline   Reply With Quote
Old 12-05-2015, 09:41 AM   #2
RSchleder's Avatar
Do you have a "stud finder"? If not, for a few bucks you can get one at any hardware or big box store. This is a great tool to find studs in your RV as well as at home.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 12-05-2015, 09:43 AM   #3
steelpony5555's Avatar
Hmm the location for my TV seems to have a hunk of plywood behind the paneling for the mount to screw too....But I do not trust the mounts...I bought a roll of Velcro at Walmart and I screw a piece above and below the TV long enough to wrap around the front of the TV. The mounts alone let the TV wobble like crazy. Wobbling like that puts a lot of stress on where the TV attaches, so the Velcro makes it more solid....
From Central Texas
2014 Cedar Creek Silverback 29IK
2010 Dodge Laramie 3500 Dually
My Steelpony....2007 HD Ultra Classic...done up in a memorial to the 343 firefighters who died 9/11
Never Ever Forget....yes I was a Volunteer FF for 20 years........
steelpony5555 is offline   Reply With Quote
Old 12-05-2015, 10:35 PM   #4
Rivet's Avatar
I have a stud finder somewhere. When I get back I'll check and ensure I'm in the studs.
That's a good tip on the Velcro straps! I'll probably do something similar.
Thanks all
Old 12-06-2015, 10:23 AM   #5
Explorer
Yep, bouncing your house down the road can cause problems.
I have done several different things to help support items:
Putting a larger board behind mounting plate(mounting bracket to board and board to hall) this way you can catch 3 studs. You can use a peace of nice wood and stain it to match.
A simple one, if the screws are just backing out, is to put some glue on the screws. I like gorilla glue because it expands as it dries. This only helps if your into good wood.
Strapping it down during transport will help a lot and should probably be done anyway.
Or just take it off while transporting, just one more item during set up and tear down.
Just a few different things I've done
John
John
2011 Wildwood T26BHXL
2004 Yukon XL Denali
43yrs of camping; one lucky guy
YoungKopernik is offline   Reply With Quote
Old 12-06-2015, 10:56 AM   #6
redneck 92's Avatar
I also used the Velcro trick. Really helped a lot.
2013 Coachmen Encounter 34TA
redneck 92 is offline   Reply With Quote
Old 12-06-2015, 11:13 AM   #7
onetonford's Avatar
On mine in the bed room The 12 box was just by it so I removed the cover and use my wife's cell to take pics in hole showing were the plywood backer is also I remove tv during travel.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is online now   Reply With Quote
mount, television
