Old 10-18-2016, 01:02 PM   #1
tire covers
So i have read on this forum that most suggest using tire covers when planning to park for an extended period of time. I am camping this weekend and probably be done for the season. I am not sure which tire cover size to purchase. My tire size is ST205/75D14C. Any suggestions?
bdhenry04 is offline   Reply With Quote
Old 10-18-2016, 01:09 PM   #2
Most of the 'how to order' directions I've seen say to measure the tires' diameter to get the correct covers.
*HERE* is how Camping World suggests you measure.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 10-18-2016, 01:49 PM   #3
Left Coast
What your trying to do is block the sun.....might only need one double or single axle style
Retired....but work part time as a pain in the north end of a south bound donkey.......2010 Rockwood 8280 5er....99 Dodge 2500 turbo Cummins
bob caldwell is online now   Reply With Quote
Old 10-18-2016, 02:36 PM   #4
BamaBob's Avatar
Spot on Bob - and you are only trying to block the UV Rays on your tires - your rims don't care
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 10-18-2016, 09:00 PM   #5
dbarr's Avatar
I use a 27-29 inch double on the same size tires. Snugs up good.
'15 F150 Ecoboost Maxtow Scab '13 Freedom Exp. 233RBS
Days camped 2016 56,
Days camped 2015 33,
Days camped 2014 47,
Years camping....50
dbarr is offline   Reply With Quote
Old 10-19-2016, 10:18 AM   #6
dodosmike's Avatar
Cut a sheet of 1/4" plywood to fit.
All your doing is casting shade, A plastic tarp would work.
dodosmike is offline   Reply With Quote
Old 10-19-2016, 10:25 AM   #7
I had a doubles for my Roo. I found that snow piled up on the part of the cover that stretched between the tires and caused it to pull the covers off. I'm using 2 singles on my Mini Lite now and not having any issues. So if you're in a snow area, I'd recommend singles over doubles.
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
rockfordroo is online now   Reply With Quote
Old 10-19-2016, 10:39 AM   #8
Commercial Member
My blog post on the topic explains the "WHY" for using white covers. UV is IMO a smaller portion of the reason with heat reduction being a major reason.
I suggest order single tire covers based on measured tire OD per ordering instructions. I use them whenever I am parked unless it is raining.
I write a blog on RV tire application and safety. RVTireSafety.com
Also give seminars on tires at RV events across the US. 40 years experience as tire design & quality engineer for major tire mfg. Freelander 23QB on Chevy chassis is my RV
Tireman9 is offline   Reply With Quote
cover, tire
