04-07-2018, 04:10 PM
Tire mounting Recommendations
Anyone have a recommendation for getting their rig tires changed in the Cincinnati area? Don't want to wait for the RV shops as they take too long. Maybe Walmart, or a discount tire place? Appreciate any recommendations!!
John
04-07-2018, 05:35 PM
Scoundrel
When it came time to change out my tires & wheels I didn't trust a tire shop to jack up my Micro Lite off the ground properly. I raised it up myself and dropped the wheels off at the tire shop.
Hope you find someone you can trust to do it right.
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
04-07-2018, 06:09 PM
Denver To Yuma In 90 Days
Don't know about your area, but whatever you do...don't let them jack it up by the axle!
If they say "Oh, it's OK...I do it every day!"
And I'm sure you will hear those words from a lot of tire stores!
And that may be true...
But they aren't the ones footing the bill a couple of thousands of miles down the road when you have to replace the axles and the tires (and maybe some gas lines, wiring and fenders due to a blowout) because they bent the axles by jacking it up that way!
I prefer truck tires shops, usually found near truck stops!
And, make sure you get them balanced!
RV dealers will tell you that trailer tires don't need to be balance...
But what do they know...
They are the same people that told the other guy that his F/150 and/or 1500 truck can pull that 14,000 pound 5th-wheeler!
04-07-2018, 06:11 PM
John
Are you going to buy the tires from the Installer or are you going to bring your "Own Tires"? This will make a difference! Also if you are going to buy the Tires from the Installer you will probably need to Order them if you want "Good Tires"! My Tire dealer in Lebanon,Ohio,sells Maxxis! I take my HD Ramp so there is "NO Jacking"I have let other Members of FRF use my Ramp when they use this Dealer,if interested I will extend the same offer to you! Youroo!!
04-07-2018, 06:58 PM
Generous offer! I'm not that far from you. Right off of 71 at fields Ertel. Was planning on buying Goodyear Endurance tires online. Make any difference in tire brand at your dealer? Let me know! I'm at jdgump999@gmail.com. Thank you!!
04-07-2018, 07:07 PM
Great just call "Walt Luti Tire" in Lebanon and see if they will Order your Tires,regardless of Brand! If all goes well just PM Me here on FRF and I will take the Ramp over in advance to Luti Tire! They balance the Tires and Torque the Wheels! Tell them you want Metal Valve stems also! Youroo!!
04-07-2018, 07:10 PM
I assume that place is fairly easy to get in/out of with a trailer?
04-07-2018, 07:11 PM
Oh and would they do the work if I did not buy the tires there?
04-07-2018, 07:19 PM
Answer to post 7 & 8! Semis drive in and out all the time! You will have to ask Them about Not Buying from them,But if it is like "Forest River Dealers that you don't buy from, the Line is Very LONG"! Youroo!!
04-07-2018, 07:31 PM
Thanks again. I'll give them a ring. Will PM you if this all works out.
04-07-2018, 07:49 PM
You should get you own tire ramp and learn how to use it... before you really need it on the road...
Brother Les
04-07-2018, 07:55 PM
Good call. I have enough leveling blocks I could make one with, but a purpose built ramp is definitely the way to go.
04-09-2018, 08:03 AM
I have the black 'Tire Aid'.... I also added a 2x6 on the bottom, extended about 4 inches on each side, to get my unit a little higher. There are four bolts on the bottom that I attached through the 2x6 for better stability. Some 'Tire Aids' have the rubber on top to make higher.. some do not.
https://www.walmart.com/ip/Camco-Tra...06&athena=true
Brother Les
