Old 05-27-2016, 06:07 PM   #1
Toilet Bowl not holding water
Toilet bowl not holding water above "flush lever" and gasket. Anyone ever had problem with this - seems like it's probably a warped gasket that's not sealing properly? This is in my 2015 Wildwood 261 BHXL...not loking at it right now, but I'm assuming it's a Dometic toilet.
Thanks!
Bunkie is offline   Reply With Quote
Old 05-27-2016, 06:11 PM   #2
Left Coast
Seals are available.......easy to change......you need to know the model to get the right seal
Retired....but work part time as a pain in the north end of a south bound donkey.......2010 Rockwood 8280 5er....99 Dodge 2500 turbo Cummins
Old 05-27-2016, 06:13 PM   #3
We've had that problem a few times and a simple wipe around the seal with some paper corrected the problem.
tkarper14 is offline   Reply With Quote
Old 05-27-2016, 06:32 PM   #4
Left Coast
The new seals, after install'n, recommend you coat the seal, where the slide ball rubs, with silicone grease that Lowe's, or HD carry in the faucet repair area
Sent from my XT1585 using Tapatalk
Old 05-27-2016, 11:12 PM   #5
Wa11y757's Avatar
Mine would leak down too. I used the lube that I use on the rubber orings on my swimming pool filter basket. Fixed it!
Now I'm going back to looking for my 10mm wrench! 2016 Wildwood 27RKSS
2005 F250 PSD
Wa11y757 is offline   Reply With Quote
Old 05-27-2016, 11:25 PM   #6
Newbie
Lynlanning's Avatar
Mine came with a glorified (plastic) Popsicle stick that you use to "clean" all around the top and bottom of the gasket. Once I did that and hit it with some silicone, it stopped leaking. Good luck!
Lynlanning is offline   Reply With Quote
Old 05-28-2016, 12:55 PM   #7
RudysWorld's Avatar
When I had that problem I used:
Thetford 36663 Toilet Seal Lube & Conditioner
And then it worked fine. May be worth trying.
Rudy - 10 year old long haired dachshund
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 05-28-2016, 01:14 PM   #8
tkmi's Avatar
Clean the seal then buy some vasiline, a jar might cost .80 cents. Makes the toielit flap real fast.
2013 Silverback 33RL
2010 2500 RAM 6.7L
tkmi is offline   Reply With Quote
Old 05-28-2016, 04:04 PM   #9
I have had that problem and to fix. I clean the gasket and area where it fits with soap/water with an old tooth brush. Also with the old tooth brush, tie a string on the tooth brush and wrist, just in case. You don't want to drop into the tank. Leave some water in the toilet so that your seals will not dry out. Then if it does not hold water, try the Thedford seal conditioner or Vasoline. If that fails, you must replace the seals.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
txredfish is offline   Reply With Quote
Old 05-29-2016, 07:12 AM   #10
Had that same problem with my 2015 Silverback and after reading the instructions for the toilet, it said to run your finger around the seal with downward pressure. Did that a few times and now it holds water.
Joe O is offline   Reply With Quote
water
