Old 09-24-2012, 03:39 PM   #1
Tongue jack
We have a 2012 wildwood x lite TT. I noticed soon after that the jack isn't mounted straight up & down. It has an angle to it, (the top tilted to the back). The a-frame is level in relation to the main frame, & with a carpenters square, the jack is noticeably angled. The dealer didn't seem concerned about it when I addressed it. Has anyone else noticed this? I've attached a picture, the propane tank cover is vertical.
2007 Dodge Ram 1500, 2012 22 ft Wildwood X-Lite TT
Blakew76 is offline   Reply With Quote
Old 09-24-2012, 09:37 PM   #2
TURBS's Avatar
For the most part I would not be concerned.
As long as it does what it's supposed to.
My guess is the triangular bracket mount was welded on the jack just slightly askew.
Turbs
Old 09-24-2012, 09:42 PM   #3
Road-King's Avatar
X2...
Or someone forgot to chock the wheels and it rolled backwards a little.
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 09-24-2012, 09:46 PM   #4
Terier's Avatar
On another note do you have any problems getting the coupler lock on? I use the same type and need to adjust it because it's a tight fit.
Old 09-24-2012, 09:51 PM   #5
TURBS's Avatar
Does yours have an adjustment nut underneath ?
Turbs
Old 09-24-2012, 09:57 PM   #6
Terier's Avatar
Turbs
No idea. If I did would it get in the way of hitching up?
I'm clueless about the nut but willing to take a peek when I get my trailer back.
PS
Sorry for the highjack.
Old 09-24-2012, 09:59 PM   #7
I contacted another dealer for a second opinion. They said as long as the jack works properly, to not be concerned. It was probably not welded on quite right. It does work properly & more importantly, nothing is bent.
I also have to angle the tongue lock, as it doesn't sit properly. I can still get it on though.
Thanks for your reply!
Old 09-24-2012, 10:02 PM   #8
Terier's Avatar
Same here too. Think it could be a tad wider to fit easier.
Old 09-24-2012, 10:04 PM   #9
Road-King's Avatar
You know this would be an excellent time to convince the DW about the need for a power tongue jack... I would never have a TT without one again. Might be worth a shot...
Russ & Kim
2014 Alpine 3600RS
Old 09-24-2012, 10:17 PM   #10
I don't mind the manual jack, though, I'm used to cranking semi trailer landing gear on a daily basis, so a little jack is no problem. .
