Old 04-08-2013, 07:13 PM   #1
BriBoy01's Avatar
Trailer Aid (Wildwood 26TBSS)
Has anyone used a Trailer Aid on a Wildwood 26TBSS? I have read a lot of reviews that say it won't lift the other tire high enough. It seems like most of those reviews are on the flex suspensions and not standard. I found a good deal on the "Plus" version which gives an extra inch of height. Is it going to work?
BriBoy01 is offline   Reply With Quote
Old 04-11-2013, 07:54 AM   #2
racecar67's Avatar
I too would like to know the answer.
racecar67 is offline   Reply With Quote
Old 04-11-2013, 08:00 AM   #3
BriBoy01's Avatar
Mine arrived yesterday. Once I try it I will post the results.
Old 04-28-2013, 04:23 PM   #4
BriBoy01's Avatar
Finally got to try the Trailer Aid Plus. I used it to raise all four wheels to check my brakes. One wheel was on a slight slope and required an additional 2x under the trailer aid but still was easy to use and worked really well.
Old 04-28-2013, 08:19 PM   #5
Always Learning
Thanks for the review- I was just looking at these.
Old 04-28-2013, 08:36 PM   #6
SYE
SYE's Avatar
I have one that worked great on my old camper, I have not tried it on my new camper yet I was told that it will not work, but I am going try it before I need it and it will not work. I also bought the trailer aid plus when I bought mine because it gives you an extra inch of lift. I have a different kind of suspension on my new 5er I believe it is a trail air, so we will see. I will let you know after I try it maybe later this week.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
SYE is offline   Reply With Quote
Old 07-11-2013, 09:10 PM   #7
We bought a 2014 wildwood 26TBSS in April and we have camped in it about 14 nights so far. We have experienced issues every time we camp, is this normal? We previously had 1998 model travel trailers and never had any issues, we thought a brand new trailer would not have issues. We like the trailer but we are concerned that it will always have problems. Does anyone have this model and if so what has been your experience? Is it a good trailer?
Slimbo is offline   Reply With Quote
Old 07-12-2013, 06:35 AM   #8
racecar67's Avatar
Mine is a 2013 so far the only problem we have had is a tree top impailing the roof back in May. Still have not gotten it back from the dealer getting it fixed
2013 Wildwood 26TBSS
2014 Ram 1500 Express CC
2013 Days camped 13
2014 Days camped 14
Old 07-12-2013, 11:28 PM   #9
BriBoy01's Avatar
What kind of problems are you having?
Old 07-17-2013, 07:48 PM   #10
The kitchen sink leaks, TV antenna does not work, there appears to be nail heads popping up under the vinyl floor and the floor in the entry way started squeaking when you step on it, the dinette table leans inward you can stand it up straight but if you lay your arm on it it leans right back over, one tire already has a bald spot, etc. We did take it to the dealer and they have been great, they are taking care of the issues however it is concerning to us.
Old 07-26-2013, 03:23 PM   #11
Hey Slimbo
I have experienced similar problems. My floor squeaks in front of the heater return vent in front of the kitchen sink. I figure the floor is hollow to allow for duct for the heater.
hfinn60 is offline   Reply With Quote
Old 07-26-2013, 03:28 PM   #12
I also have the nail pops in the vinyl. I returned to the dealer for this. They say it may be sawdust under the vinyl. They would have to only cut out the affected area repair and then patch in the vinyl. I am not interested in this solution. I know I will never be happy with their hurry up patch job. Some things are better off not being opened up as they never are as good as the factory install. If it continues to get worse I will address it with Forrest River probably not thru the dealer to get a 2nd opinion.
Old 07-26-2013, 03:34 PM   #13
I notice the nail pops. My wife hasn't seemed to notice. I have made her aware of it. They are not terribly bad as of yet. Not worth their cheap *** patch job.
I also asked the dealer about installing a roof air vent over the queen bed. They said " we will have to do some engineering and cut a hole in the roof to install. $500. I'm afraid not, $500 for a $30 vent sounds like total bs to me. I'll do it myself if I absolutely have to have it. Right now I just crack open a window.
Let me know what you have done to your floor please.
Huck
