Old 07-02-2012, 06:59 PM   #11
Originally Posted by mountain matt View Post
U know what I tried plugging it in and it wouldn't go..I had a boat trailer that plugged into it a few years ago but I had a adapter that I borrowed....it wasn't my boat
Suggest taking a picture of both and posting them.
Old 07-02-2012, 07:03 PM   #12
mountain matt's Avatar
Ok thanx bro
mountain matt is offline   Reply With Quote
Old 07-02-2012, 07:08 PM   #13
Do u know what size generator I need for 19foot wildwood??
Old 07-02-2012, 08:05 PM   #14
jtstromsburg's Avatar
About a 26"er.
Depends on what you want to run? Some get by with a 2400 but suggest dual 2000 Hondas with a companion kit.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 07-02-2012, 09:41 PM   #15
bikendan's Avatar
will you use it in a campground or boondocking? makes a big difference. a cheap open-framed gennie will be fine for boondocking but not for campgrounds and neighbors.
you have to choose if you want quiet or cheap, can't have both.
to run everything except the a/c, a 2000w inverter generator will be fine.
if you want to run the a/c and have a 13.5 btu a/c, a Yamaha 2400 would be the minimum and it would have to be a newer a/c.
otherwise, a 3000w one should do all unless it's a 15k a/c.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 07-02-2012, 10:09 PM   #16
Right on thanx!!!
Old 07-09-2012, 06:07 PM   #17
You sure you are not trying to plug a 7 pin into a 6 hole are vice x versa.
If both of them are 7pin connectors it should work let us know what you find>
2005- WDF27RLSS
2001-Dodge-4/4- souped up Cummins
1953 Willys 4/4
1970 Restored Cushman Trackster
Olratlr is offline   Reply With Quote
Old 07-09-2012, 06:12 PM   #18
Too old to be too smart
SpringerPop's Avatar
What was the resolution to the original question from Matt?
Pop
2005 Terry 250RKS, perfect for the two of us and the pups.
It recently replaced our Flagstaff 21FB (which we still have)
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
Old 07-09-2012, 06:38 PM   #19
A 7-pin is different than a 7-blade connector. You may need one of these adapters if that is the case:
7-Way Blade to 7-Pin Adapter for Towing a Trailer with A 7-Pin Connector | etrailer.com
make sure the male/female ends are correct if you think you need one of these.
SCOC is offline   Reply With Quote
