Old 02-09-2016, 04:22 PM   #1
jgump's Avatar
Trailer Wheels Alignment- Have you ever seen this?
Question for everyone. We recently purchased a Wildwood 27RKSS and brought it home about a week ago and backed it up into the driveway for a week or two to stock it and hang out. One thing I've noticed is the the front wheels of the tandem wheels are a little skewed from the rear wheels. Do you believe this could be due to backing it up into the one side of the driveway and as the trailer "turned" into its final spot aligning with the edge of the driveway the wheels just "torqued" a little as I swung it into place? It's only an inch or so and it hasn't moved since, so I'm hoping that when we hook it up again to take to storage they'll straighten out. Any thoughts would be most appreciated. Thanks all
John
jgump is offline   Reply With Quote
Old 02-09-2016, 04:25 PM   #2
TURBS's Avatar
John, that's exactly what is happening.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 02-09-2016, 04:33 PM   #3
jgump's Avatar
Thanks Turbs! Do you think there's anything for me to be concerned about leaving it sit this way for now?
Old 02-09-2016, 04:40 PM   #4
Leaving it puts unnecessary stress on the tires, wheels and bearings. Pull it forward until it straightens out and back up straight to the parking position.
phillyg is offline   Reply With Quote
Old 02-09-2016, 05:05 PM   #5
jgump's Avatar
Thanks Phillyg. Once this snow melts in a couple days I'll do exactly that.
Old 02-10-2016, 01:10 PM   #6
Robbsails's Avatar
I had a similar problem but I had a flat spot on one of my tires...come to find out one of the axels was a little cockeyed (3/4 in.) apparently a nut got loose and the Axel shifted a little. So after replacing the tire, I check it every so often!!! Good luck.
Robbsails is offline   Reply With Quote
Old 02-10-2016, 02:04 PM   #7
Two ways to address the issue. Hook up and pull straight forward, then straight back. Or, jack the wheels up on each side to allow the wheels to align. It is not wise to leave the tires/wheels contorted. Wheel torquing is a given when turning a tandem axle trailer. The tighter the turn, the more they torque.
PenJoe is offline   Reply With Quote
Old 02-10-2016, 05:14 PM   #8
I'm glad to read this thread because I've had this happen and was worried about the overloading the axles. I finally figured it out after noticing the trailer was in a torque condition when parked at a gas pump. They straightened up once I pulled forward. Thanks for input!!
gfarmcafe is offline   Reply With Quote
Old 02-11-2016, 01:26 AM   #9
moondog2000's Avatar
This is some good information. I have to cut the trailer hard to get in my driveway and there was a lot of popping noise going on so I also noticed my trailers tires were torqued a little and not in line when I checked under my trailer.I guess I'll jack it up and take the load off.
05 Silverado Z71 4X4
2013 Forest River X-LITE
Days camped in 2018, 27
moondog2000 is offline   Reply With Quote
Old 02-11-2016, 10:26 AM   #10
Wheels oh wheels whare are you going
John
Yes you are correct but to really answer your question in full, again yes you are correct that the wheels will move a ton while you backup and other times while turning the couch, BUT you are also on the correct track in your thinking that yes the "axles" on your trailer SHOULD be aligned and that is what a "correcttrack system does, many newer coaches come with it, and the dealer in most cases will not do anything with a new coach unless you ask, so if it did not come with the system and you plan to do a good amount of travel you should do the upgrade to save the tires, the suspension and the coach
Hope some of this helps and Happy Camping
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
alignment, trailer, wheel
