Old 06-26-2019, 08:49 PM   #1
Triangles near bumper under frame function?
I want another way to store a sewer hose and the best spot is where these are welded. Can I cut those off and put 5x5 vinyl post cover with sewer hose where they are?. I have a 179dbk. !Click image for larger version
forsakentalon is offline   Reply With Quote
Old 06-26-2019, 09:15 PM   #2
Flybob's Avatar
Those are skids to protect the jacks and the back of the trailer. Depending on where you tow, they will get wear. Replacing with a plastic post cover may result in the post cover being destroyed on an incline. If you want to add a sewer hose holder, I would mount it closer to the axles as there will be less clearance issues.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-26-2019, 09:28 PM   #3
X2. One day very shortly, you will roll into (or out of) a gas station, hear a screech from your TT, and be very glad you've got those triangles!
From your pic, looks like you could easily sling the fence post under the bumper (or above it).
2011 Traverse LT, 3.6L, FWD
Old 06-26-2019, 09:35 PM   #4
Wife didn't like those spots above or below the main bumper. Thought of getting an hdpe sheet aka marine board and cut some slats to go inside the triangles. But marine board is pricey. Can't put it next to the axles as my tanks are in those spots and hang below the frame.
Old 06-26-2019, 09:58 PM   #5
Why not take the bumper cap off and store the sewer hose in the bumper?
billybigrigger is offline   Reply With Quote
Old 06-26-2019, 10:06 PM   #6
My rhino connectors and black flush adapters don't fit in there
Old 06-26-2019, 10:09 PM   #7
I store my hose in the bumper. I remove the caps and adapters and place them in small container when not in use.
Old 06-27-2019, 12:50 PM   #8
Paint a 5" PVC fence post (available at Lowe's) black and mount it above or below your bumper - or in the triangles - post caps can be attached several ways to the ends of the post to secure.
RkwdNewbie is offline   Reply With Quote
Old 06-27-2019, 12:53 PM   #9
It doesn't fit inside the triangles though. And wife doesn't want it on the bumper. Tough crowd to please lol
Old 06-27-2019, 01:00 PM   #10
I thought those triangles are a lot wider than 5" at a point 5" down from the frame?? it seems that you could secure to the frame inside the triangles???
frame
