Old 06-09-2016, 11:04 AM   #21
Restcure's Avatar
Originally Posted by lbrjet View Post
JD, the truck bed is moving, OP said nothing of trailer sway. This is a truck problem, not a hitch problem.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
After re-reading it I see you're right. I agree that if the wiggle originates with the truck, no hitch is going to make it go away. If the trailer is causing it, that's a different story.
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
Restcure is offline   Reply With Quote
Old 06-09-2016, 11:27 AM   #22
Trailer/RV sway control
I have installed Timbren axle stops on the last three trucks/RV's I have owned. A Dodge D250, Ford F150, and a Forest River Mercedes Sprinter Solaris. They extend the normal axle stop clear to the axle which limits the amount of travel before the chassis can sway before it hits the axle. They have made a huge difference in handling...Highly recommended. There is a good visual of it at this site...
Timbren Suspension Enhancement System - TruckSpring.com
Hope this helps...
Marty, Carla, Gabby and our ankle biter Rocky
2011 Dodge Ram 1500 SLT Big Horn 4x4 Hemi 5.7
Forest River Wildwood 30KQBSS[/QUOTE]
Highway is offline   Reply With Quote
Old 06-09-2016, 11:39 AM   #23
ov845's Avatar
I would be curious to see what the CAT Scales say. I had similar rear end sway, installed air bags and readjusted weight on the trailer, now it's gone.
Happy Camping!
2012 Ram 1500 Crew Cab 5'7" Bed
4 X 4 Engine 5.7L Hemi Gear 3.92
Airlift 1000
2015 2809W Windjammer (Diamond Package)
Husky Centerline WDH
ov845 is offline   Reply With Quote
Old 06-09-2016, 11:39 AM   #24
My Pops had that issue with his 1500 Ram and installed airbags to balance weight and upgraded to D rated LT tires. He had no further issues.
2015 Tracer ultra light executive edition 3200bht
2007 Dodge Ram 3500 Cummins 6.7, Dually, crew cab, long bed
SilverArrowPro is offline   Reply With Quote
Old 06-09-2016, 11:58 AM   #25
CaptnJohn's Avatar
No hitch is going to eliminate a truck suspension/tire problem. Once done a properly set Equalizer 4 point is all that is needed unless he has extra cash to throw away.
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
CaptnJohn is online now   Reply With Quote
Old 06-09-2016, 12:06 PM   #26
You might want to try a Hellwig rear anti-sway bar. I installed one on my F150, and it made the truck much more stable.
GaryHowe is offline   Reply With Quote
Old 06-09-2016, 12:06 PM   #27
ARLO
I have discoverer HT3 Load range E 10 ply on my 2014 F150 and TowMax Load range E 10 ply on my 829FKSS. No sway problems. I actually swpaaed tires from my 2011 F150 to the new truck and gave the dealer the P rated mushballs. I won't tow with P rated tires.
rlocicero is offline   Reply With Quote
Old 06-09-2016, 12:22 PM   #28
Stormrider151's Avatar
I had the same issue with my F150. It wasn't really a sway but better describe as a wiggle. Ditched the P's and put LT E's on it and run them at 65 psi. Problem solved.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 06-09-2016, 12:45 PM   #29
Thanks everyone
Marty, Carla, Gabby and our ankle biters Rocky and Addy
eyeguy1 is offline   Reply With Quote
Old 06-10-2016, 07:30 AM   #30
Do you have a 6.5 bed or an 8 foot ,the longer the wheelbase the less sway you will get ,and the hensley hitch will help...
Save a beer for me!!! Happy Trails....Be Safe....
sunnyinfla is offline   Reply With Quote
sway, towing, truck
